Shorai for battery replacement?
Hey guys. Panasonic has died after a long life of 4 years. Looking to upgrade to a lightweight battery. I'm considering a Shorai LFX27L3-BS12 or LFX36L3-BS12. Car is in Alabama , DD, and has Rockford system. Thoughts? Or is the weight savings not worth it and should go with stock one? Also, where can I get something like a terminal adapter, since technically it's a motorcycle battery and all. Thanks in advance!
Awesome. Thanks for the reply. Did you use terminal adapters or install new terminals? Which Shorai did you go with?
Bump for an update on Shorai lithium batteries.
My Deka ETX20L is starting to die on me after 2 years of DD use. It will hold charge for about 24 hours, if I leave my car for longer it needs a jump.
I was about to just order another one but am now considering alternatives. I am looking at the following Shorai model, it has similar CCA as the Deka battery.
LFX24A3-BS12
Weight:3.97 lbs
1.80 kg
Cold Cranking Amps:360
Any insight or experience with these batteries is appreciated.
LFX24A3-BS12
Weight:3.97 lbs
1.80 kg
galownia
May 8, 2018 12:21 PM
FS[Northeast]: Shorai battery with MP Fab bracket
michaelrc51
14
Aug 28, 2015 04:26 PM
MRevo916
Feb 3, 2014 06:20 PM
Turbo Jeebus
16
Jul 16, 2008 08:24 AM
