ACD pump rebuild
Old Jan 28, 2018 | 06:55 PM
  #31
chadnick's Avatar
Great rebuild
Old Apr 12, 2018 | 08:11 PM
  #32
gotyaw?'s Avatar
Great work! I have to do this soon, I'm throwing it in the trunk once I'm done!
Old Oct 1, 2018 | 02:24 PM
  #33
Wertigo's Avatar
  • Hello, everyone decided to lay out another portion of their repair for the restoration of pumps ACD AYC.:круто:
Old May 31, 2019 | 03:36 PM
  #34
Wertigo's Avatar
Old May 31, 2019 | 03:41 PM
  #35
Pal215's Avatar
Very nice work OP. We need more SME's on this forum. Would help us work collectively as a team.
Old May 31, 2019 | 07:31 PM
  #36
moladin's Avatar
I am just glad he is still doing it after all these years. Keep up the good work!
Old May 31, 2019 | 11:22 PM
  #37
Wertigo's Avatar
Yes, I did not abandon this case. but he also thought about how to refine the rate of pressure gain. it also turned out to achieve maximum pressure higher than that of the new pump
Old May 31, 2019 | 11:25 PM
  #38
Wertigo's Avatar
if that I am ready to help you with either advice or components for repairs or ready-made pumps. p.s at the moment I have done more than 200 pumps in Russia and CIS countries
Old Jul 6, 2019 | 08:52 PM
  #39
midnightsuns's Avatar
Good post. Done about 20 of these here in Dallas where the brushes in the motors went bad. We dont really see the corrosion issue mostly just bad solenoids and burnt out motors.
Old Jul 7, 2019 | 10:19 PM
  #40
Wertigo's Avatar
[font][font][QUOTE = midnightsuns; 11878920] Хороший пост. [/font][font]Сделано около 20 из них здесь, в Далласе, где щетки в моторах испортились. [/font][font]На самом деле мы не видим проблемы с коррозией, в основном просто плохие соленоиды и перегоревшие моторы. [/ QUOTE][/font][/font]
Are you recovering burned out motors? the only right decision is to install an electric motor from 7-9 evo. Tell me how much you give a guarantee on your work?
Old Jul 14, 2019 | 05:57 AM
  #41
Wertigo's Avatar
hi everyone, another selection of complete rotten ACD AYC very rotten pumps
I also have the brains of the SST trasmice and the gearbox from Japan. maybe someone will need it.
Old Jul 16, 2019 | 09:24 PM
  #42
W4r3z's Avatar
How do you install the EVO 7-9 Motor on the Evo X Pump ? Where do you source them ? Thank's !
Old Jul 17, 2019 | 05:16 AM
  #43
Wertigo's Avatar
you yourself will not do. I use the motor and the central part with the EVO 7-9 I merge with the pump casing EVO 10. if you want to upgrade, you can send me your pump.
Old Aug 16, 2019 | 10:15 AM
  #44
High_PSI's Avatar
I'd love to Mail you mine for a rebuild. It works fine it just leaks like a sieve , no idea why.
Old May 8, 2020 | 12:42 AM
  #45
Wertigo's Avatar
I want to introduce you the ready-made pumps ACD AYC EVO X St1 St2
