Need your opinions, thinking of changing my clutch set up
Old Sep 28, 2015 | 04:40 PM
rafaron's Avatar
Hi guys, so like the title says, I think I need a new clutch set up. I recently bought a 2013 GSR which has clutch master stage 4 FX400 6 puck ceramic. The car is making 400+ whp on dyno.
I think I can get used to it because it's not so stiff on the clutch pedal, the only problem is that it engages pretty fast and I'm having a hard time launching smoothly from first gear and at times, I would stall on inclines.
I'm planning to make it a DD, so called COBB and their advice is replacing my clutch kit with a more street friendly competition clutch stage 2. Anybody with this stage 2 set up, I need your thoughts. Or should I just settle with my current set up and learn to live with it..
Old Sep 28, 2015 | 07:24 PM
rafaron's Avatar
Or if you know a better clutch kit ideal for daily drive, I need your advices.
Old Sep 29, 2015 | 10:33 AM
evostanman's Avatar
I'm DDing with the CC stage 3. No problems so far
Old Sep 29, 2015 | 07:31 PM
rafaron's Avatar
So competition clutch kits must be a good choice. I'll do more research on that.
Old Sep 29, 2015 | 09:25 PM
ghozt's Avatar
I second competition clutch. Right now I cant remeber if I have stage 2 or 3 but yes... However I will say by your description changing your clutch won't fix your issue imo. The experience you have is pretty much what mine feels like too and I think it's the nature of the X somewhat. I have a lightweight flywheel and that contributes to symptoms like your describing. Do you know if yours has a lightweight flywheel? I'd go back to Oem if so, if/when you do a clutch swap.
Old Sep 29, 2015 | 10:00 PM
rafaron's Avatar
I still have my stock flywheel so I don't feel any chatter, it's just that stage 4 clutch seems to have harsh engagements. As much as possible, I don't want to downgrade but I'm more concerned about daily driving. I guess it's part of the tradeoff of having a performance vehicle. I'm still gonna try to give it a week or so and see if there will be any improvement on my learning curve.
Old Oct 8, 2015 | 06:32 AM
HatrixMouse's Avatar
You'll experience more chatter/harshness with any 4/6 puck clutch. If you want better drivability, you'll want a full-faced clutch paired with the OEM flywheel. An aftermarket flywheel on a single disk clutch is overkill and more of a pain than what you're getting out of it.
Double/triple disk clutches usually come with their own flywheel, which is the only time (imo) an aftermarket flywheel should be used.
Old Oct 9, 2015 | 12:08 AM
rafaron's Avatar
Thanks for the replies. Any suggestions of a good full faced kit? I'm leaning towards competition clutch stage 2... but if there's another good brand, please feel free to give me feedbacks
Old Oct 12, 2015 | 01:38 AM
BubbaEvoX's Avatar
I'm getting a competition stage 2 clutch installed Tuesday. From what I heard its a good daily. I'm upgrading the cmc and monoloc as well.
Old Oct 27, 2015 | 02:56 PM
Mitch Master T's Avatar
You should change your setup - The Exedy OEM equivalent one from MAP is pretty nice (I'm running it right now).
Old Oct 29, 2015 | 06:08 AM
jakgal04's Avatar
I have a Competition Clutch Stage 3 (2600 series) with their lightweight flywheel. The clutch is great, but I would put the OEM flywheel back on anytime for a DD setup. You have to give it slightly more gas than normal and makes it difficult when going up inclines. I highly recommend the Comp clutches though!
10SEKNDMR
Jul 8, 2008 06:17 PM
Lostprophet
Oct 31, 2007 08:35 AM
blackonblackevo
Feb 1, 2007 02:11 PM
hurley
Jan 29, 2007 08:43 PM
