2013 evo x clutch problems
Old Nov 17, 2015 | 11:56 AM
johnrocks's Avatar
Hey guys I need your help, I was driving my car on the freeway, went to shift gears and my pedals collapsed to the floor. Towed it home check the master cylinder for leaks and by the pedal and there was no leaks. I was able to pump the clutch up and it held pressure but wouldn't engage. Not sure if there's air in the line. I replaced the clutch with a exedy stage 1 heavy duty clutch kit less then a year ago. Thanks a lot
Old Nov 18, 2015 | 06:58 AM
evo-2014's Avatar
No broke master plastic cilinder.?????
Old Nov 18, 2015 | 08:32 AM
johnrocks's Avatar
Nope it's not broken. They said they think the fork is broken
Old Nov 18, 2015 | 02:44 PM
inslowoutfast's Avatar
It may be a broken throwout bearing and/or the collar. When you do replace your clutch I highly recommend the ACT MONOLOC.
Old Nov 19, 2015 | 06:22 AM
jakgal04's Avatar
Can you check the fluid level just to be sure? When my cmc broke it didn't look like it was leaking until I took the brake booster out and saw it close up. The clutch forks are usually pretty strong and rarely break. Can you have someone push the clutch in while you look at the slave cylinder under the hood?
Old Nov 23, 2015 | 11:28 PM
bobssecrtsn's Avatar
check the actual fluid in the salve cylinder pressed in
Old Nov 26, 2015 | 08:39 PM
johnrocks's Avatar
So some how I broke the clutch fork. Thanks for all info
Old Nov 27, 2015 | 05:51 AM
evo-2014's Avatar
DAMN...!!!!! Is the first time than i see this..!!!
dacks
Outlander Sport
27
Jan 28, 2020 04:31 AM
him
Lancer Troubleshooting
Jan 26, 2013 03:49 PM
Chadbee@Forged
Mar 8, 2012 07:11 AM
BaLListic_EVO
Mar 26, 2005 05:46 PM
