One stud holding up my turbo upgrade
Old Mar 10, 2016 | 12:23 PM
h4ckluserr's Avatar
Hey EvoM, I need your help. I picked up the MHI 18k and I'm in the process of removing the OEM turbo. Well, there is one stud on the OEM turbo that I CAN'T get off. I've never hit a stud so stuck. It's one of the studs holding the exhaust manifold to the turbo. I would describe it as the stud in the rear passenger seat.(I hope that translates)
Well, I've got everything else for the manifold removed and now I'm ready to life it out. Most of the turbo is disconnected as well, fluids drained, lines plugged/pinched, etc... Here's what I've done so far. All of these attempts have applications of PB Blaster and/or WD40 between them.
1. two nuts to torque out
2. propane torch to heat it up
3. Welded a nut to the stud to remove it(Not the end of the world if I have to cut it off)
4. chisel + hammer at different angles to try and loosen it up.
I'm frustrated to the point that I'm going to call a professional out to freeze/drill it out. Has anyone else run into this, and if you have, what did you do?
Old Mar 10, 2016 | 01:58 PM
hoobastnk90's Avatar
eeek man sounds like you have tried all the different routes.. maybe a better torch to get it cherry red hot that would be the only thing that would work I would think besides cutting it.
Old Mar 10, 2016 | 02:23 PM
KVandy15's Avatar
I'm guessing you have the manifold unbolted from the head and the manifold is now only captive to this stud right? I'd prop the manifold up a bit so you don't scuff the flange, maybe slide some tape in there to plug the inlets on the turbo, grab a hacksaw blade, get in there and cut it flush on the turbo flange. That should let you get the manifold out and subsequently the turbo. If you need to get that stud remnant out of the turbo do that on the bench after you get it out of the car.
Hope this helps, I just did the same turbo swap last week so I hope I know what I'm talking about
Edit: Was also just thinking you have a gasket in there too so if you cut on top of the gasket you should be able to avoid damaging anything but the stud and the gasket. Good luck.
If you removed all the manifold to head studs instead you might be able to get it out without cutting the stud off too.
Old Mar 10, 2016 | 02:34 PM
e_kobz's Avatar
Had this same issue a while back. Nothing I did got that damn stud to move. Had to take it to a company that had a EDM machine and they got it out in 30 minutes.
Old Mar 11, 2016 | 06:23 AM
h4ckluserr's Avatar
Originally Posted by KVandy15
...grab a hacksaw blade, get in there and cut it flush on the turbo flange...
This is pretty much where I'm at now. I am picking up some new dremel wheels on my way home today. I'm not super worried about the integrity of the stud or turbo. I bought the upgrade because my turbo seized so it needs a rebuild/repair regardless.
Old Mar 11, 2016 | 06:31 AM
e_kobz's Avatar
Find a local shop with a EDM. They can remove it and it won't harm the existing threads
Old Mar 11, 2016 | 06:55 AM
saxon's Avatar
works great
Titan - Stud Puller With Drive - Socket Wrenches - Amazon.com Titan - Stud Puller With Drive - Socket Wrenches - Amazon.com
Old Mar 11, 2016 | 06:59 AM
e_kobz's Avatar
Originally Posted by saxon
I tried this. This works great unless the stud is seized in which case all you'll do is just destroy the threads on the stud
Old Mar 11, 2016 | 08:10 AM
h4ckluserr's Avatar
I feel like if I needed to retain the stud I would pay the money for a specialized bit like this. Seeing as I don't, I'm just going to cut it between the exhaust mani and turbo and move on with the project.
Old Mar 11, 2016 | 02:03 PM
saxon's Avatar
It's only $10, heat the he'll out of the manifold and use the extractor with a impact and it will come out
Old Mar 11, 2016 | 08:27 PM
KVandy15's Avatar
If the turbo is already hosed, then my comment x2.
Old Mar 14, 2016 | 07:07 AM
h4ckluserr's Avatar
It's a good suggestion, but there's a few reasons I'm not doing this. It's not about the $10, it's about $10 I don't need to spend. I can't get any sort of ratchet on the stud/nut because of the exhaust runner on the manifold. AND I don't need to save the mounting hardware because I'm going to be replacing the entire unit plus converting to bolts.
Not to mention not owning any impact tools.
Old Mar 15, 2016 | 09:58 AM
KVandy15's Avatar
Any update? How did it go?
Old Mar 15, 2016 | 12:22 PM
h4ckluserr's Avatar
Unfortunately my weekend got away from me so I didn't put any work into it. I'm going to be picking up the new dremel wheels tomorrow after work probably. Today is the Florida Primary so I don't want to waste any time getting home from my office because the line is already going to be super long.
blackonblackevo
22
Aug 13, 2007 04:55 AM
blackonblackevo
Jul 20, 2007 10:51 AM
blackonblackevo
Jul 19, 2007 01:42 PM
C6C6CH3vo
15
Oct 24, 2005 05:41 PM
