need help! High Idle!
Old Mar 13, 2016 | 07:54 PM
u4styx's Avatar
A few weeks back I had a clutch masters clutch and flywheel along with the clutch master cylinder installed. Since I got it back I have had some serious issues with idle. IT was perfectly fine before. Now in the morning it idles fine till warm up then seems to bog down and goes lean on my AFR. usually at around 700 rpm. Then the more I drive it the worse it gets at idle. If i come to a stop at a light the RPM shoot to 3-4000 and just hang there. If I stepped on the clutch, they would go back down, then rise back up again. Now stepping on the clutch doesnt do anything the RPM just hangs there. I have removed all of my piping and re-installed. Checked for vacuum leaks and ensured all hoses are connected. New spark plugs. Disconnected the wire harness on the throttle body to see if it was faulty. Reset the ecu and reinstalled my tune. I tried the relearn and it didn't work. All grounds that I can see from the top are connected. Cleaned the MAF. Anyone have any Ideas? Im not throwing any codes.
Old Mar 15, 2016 | 08:12 AM
jakgal04's Avatar
Clutch install is a fairly involved job. Wires, hoses, connectors and bunch of other sh*t has to get disconnected. I would double check everything, especially the FPR hose. 90% of problems are from previous work.
As odd as this sounds, check the terminals on the ECU as well. I had this weird problem where the car wouldn't start, all of the lights on the dash would flash and the gauges would shoot up and down. Turns out ECU pin 91 was bent.
Old Mar 16, 2016 | 07:08 PM
u4styx's Avatar
My tuner Chet found the issue. O-ring was missing from cmc.
89turbosupra
Oct 9, 2015 09:51 AM
TJs98GT
Aug 15, 2012 02:42 AM
Toxin
15
Mar 14, 2009 12:47 PM
tt412
Jun 8, 2005 05:54 PM
