Tomioka 5.00 Final Drive gears
Old Aug 29, 2016, 08:13 PM
moparfan's Avatar
What is the intended use?
http://www.tomiokaracing.com/index.p...peed-5-00.html
Old Aug 29, 2016, 09:18 PM
detroit pistins's Avatar
This is what they are stating on their;
"TR Final Drive Gear Set raises the overall gearing of EVO. It enables the modification of the final gear ratio, adjusting the power band and gear ratios to tune better performance car. Kit includes center ring gear and output shaft."
if it is still unclear, then I suggest you read up on how gear mechanism and ratios work.
Old Aug 30, 2016, 08:52 PM
moparfan's Avatar
Awesome post...
What are these used for?
I think when the ratio goes in this direction the largest YAW effect from AYC is increased.
Old Aug 31, 2016, 10:30 AM
LetsGetThisDone's Avatar
Received 1,546 Likes on 1,325 Posts
These will further shorten the gear ratios of the X. You'll have higher rpm on the freeway, the car will feel snappier when accelerating, and you'll stay in each gear for less time due to the final drive ratio being shorter.
Old Sep 2, 2016, 04:01 PM
RazorLab's Avatar
Received 1,043 Likes on 762 Posts
Why you would want to go even shorter I have no idea...
Old Sep 2, 2016, 08:03 PM
Bhsj13's Avatar
yea with a top speed of 100mph
Old Sep 3, 2016, 06:20 AM
moparfan's Avatar
That's what I'm wondering. The overall final drive ratio would be a little shorter (6%) than the the Mk1 MR-2: stock GSR 3.54, stock MR-2 3.66, and Tomioka GSR 3.75. I bring up the OG MR-2 becuase 80s cars had notably short gears. Of course the arguments for taller gears and turbo cars , building boost earlier and staying in boost, don't apply with the taller gears.
They got made so somebody thinks there's a good reason for them.
Lucas English
60
Jun 16, 2015 04:11 PM
JohnBradley
26
Dec 8, 2013 05:42 AM
Edo Performance
EvoX 'For Sale' Engine Internals and Drivetrain
Nov 21, 2011 04:03 PM
Edo Performance
Evo 'For Sale' Engine Internals and Drivetrain
11
Nov 21, 2011 04:02 PM
maperformance
Sep 21, 2011 12:45 PM
Quick Reply: Tomioka 5.00 Final Drive gears
