CEL Then Engine Ticking
Old May 8, 2017 | 02:24 PM
dvniemela's Avatar
Hello all! Today while driving the X I did a mild 2nd gear pull. Car sputtered and the CEL flashed and the engine started to make a loud ticking noise, RPM dependent. I pulled over immediately and shut the car off. Checked oil and over the engine to see if anything looked odd. Started the car up and noise was still there, then disappeared. Drove the car home and did not make the same noise again. Car drives fine, AFR's are fine cruising. I have not done any other pulls at all. Any ideas?
Old May 10, 2017 | 01:00 PM
jakgal04's Avatar
A flashing CEL and sputtering sounds like a misfire. Check your plugs, though I'm not sure how that relates to the ticking sound. Is it different from the normal injector ticking?
acct918
10
Mar 9, 2019 04:38 AM
ecl27
Dec 9, 2011 09:46 AM
Vibrant
Sep 17, 2008 01:34 PM
Motaz
Jan 14, 2005 04:27 PM
