Solid mounts ?
Old Jul 23, 2017 | 09:48 PM
Evolution_(IX)'s Avatar
Solid mounts ?
Will a torque solutions solid engine mount make the car vibrate ? Specifically the front mount where the rad is ?
Old Jul 23, 2017 | 10:48 PM
4b11slayer's Avatar
No you should be ok.
Youd feel more vibration if you did all solid mounts.
Old Jul 24, 2017 | 08:51 AM
ddlopresti's Avatar
i did that mount change and there is definitely more vibration at idle, but it isn't bad at all. Noticable in the cabin though.
Old Feb 9, 2022 | 02:45 AM
al jawaf don's Avatar
hello
Make sure your front suspension is in good working order. Wheel hop from the shaking sounds severe, and it's probably not safe to drive at high speeds until you've resolved the problem. If you're not concerned enough about driving it, you can look into the eclipse ball joint issues. turkish citizenship requirements investment in turkey
JDMV8
Jan 6, 2022 03:52 PM
Rmeister007
Aug 21, 2012 08:23 PM
asu11
Jul 21, 2011 07:33 PM
shadow1
Jan 14, 2008 08:05 AM
fitbikedominick
10
Apr 10, 2007 02:41 PM
