Manifold temps raising rapidly
Old Sep 14, 2017 | 10:44 AM
LSs1Power's Avatar
Im puzzled by the car behavior and would like some help from you gents.
My AMS Intercooler has always been very efficient matching Manifold temps to IATs. Lately its raising rapidly under WOT and increasing 18 F by the end of 4th gear which is making the car detonate. Seeing 10 degree knock on Cobb.
What is puzzling is that i sprayed Methanol and tried different mixes between 50/50 all the way to 100 meth and temps are still not going down at the manifold. Before meth used to drop temps below IAT by at least 25-30F.
What could cause this?
Old Sep 15, 2017 | 09:51 AM
LetsGetThisDone's Avatar
Pull the charge pipes off, see if there is a nice coating of oil in them, and in the intercooler. Maybe time to clean it out.
Old Sep 15, 2017 | 08:18 PM
Jaraxle's Avatar
If your also seeing that your running more rich that you used too, then a boost leak can cause the turbo to throw some hot air since it essentially moves out of its efficiency range. Boost leak check would be in order. I would def check for the oil coating first though!
santacruzccs
Feb 6, 2015 03:37 PM
HN7
Sep 9, 2011 07:09 AM
RTW EVO
Aug 16, 2009 03:14 AM
Monkey
Aug 26, 2004 09:50 AM
