Ralliart EVO swap engine ticking noise
Old Nov 14, 2017 | 04:21 AM
Vegeta_Ra's Avatar
I have a ralliart evo x 20g turbo swapped. Tuned etc. Stock internals. Recently I've been getting a ticking noise while driving. It' only under load and when I'm on the throttle. It's not super loud. But hella annoying. I can't find anything loose in the engine bay. It sounds like its on the driver side. Ive removed heat shield on manifold thinking it was that. But its still there. Im not sure if an exhaust leak would cause it. Any input would be helpful. thank you
Old Nov 15, 2017 | 05:47 PM
Vegeta_Ra's Avatar
Bump.... some help
Old Nov 20, 2017 | 07:36 AM
jakgal04's Avatar
Ticking is farely normal on the Evo engine. Are you sure it's not just the injectors? Post a video on Vimeo or Youtube if you can.
Old Nov 22, 2017 | 08:21 AM
revzilla's Avatar
It could be valve train noise, not good if it's very loud, but hard to tell without knowing what it sounds like
deneb
Mar 4, 2015 01:48 AM
evohmoob
Aug 27, 2013 03:50 PM
Deft-one
Aug 7, 2010 11:56 PM
skans789
Oct 16, 2009 02:49 AM
Thunder-rush
Apr 20, 2004 03:27 PM
