EVOX rear differential mounting brackets
Old Jan 8, 2018 | 06:24 PM
GRNMCH's Avatar
Does anyone know if Mitsubishi used the same mounting bolt pattern between EVOX EVO8/9 and 2G DSM? In other words, will EVOx brackets fit EVO8/9 or DSM diffs?
They sure look similar but I wonder if anyone has these parts on hand to check?
Attached Thumbnails EVOX rear differential mounting brackets-ac52dc26-7c0c-413a-ab33-ad141c2b1627.jpeg
Old Jan 9, 2018 | 06:01 AM
theblackbeast11's Avatar
last i knew they are diff, ralliart uses a evo 8/9 rear diff and the mounts for that lets you bolt a evo8/8 diff up but then you need there drive shafts as well
Old Jan 9, 2018 | 07:32 AM
static_set's Avatar
Since Magnus offers an Evo 8/9 rear diff conversion kit - I'm going to have to assume they're different.
Old Jan 9, 2018 | 08:00 AM
LetsGetThisDone's Avatar
Brackets are different
Old Jan 9, 2018 | 01:11 PM
GRNMCH's Avatar
I know they are different, the mounting to the car side is different. I am asking if you can mount EVOX brackets to EVO8 diff. Perhaps I need to ask Marco.
Old Jan 9, 2018 | 03:17 PM
Or up your google-fu.
3 minutes. X side mounts bolt to CT9a rear diff...
http://www.evoxforums.com/forums/showthread.php?t=77794
Old Jan 10, 2018 | 03:57 AM
they offer a kit do you have a link to this ? have never seen it !!!
Old Jan 10, 2018 | 01:58 PM
GRNMCH's Avatar
Thanks for that link, it has confirmed that all EVOs have the same bolt pattern.
Does anyone happen to know if it is the same pattern as 2G DSM? Again, it looks the same...
Old Jan 10, 2018 | 02:22 PM
I'm pretty sure the 2g shares the rear diff with the Evo3.
Freebs
34
Jan 8, 2014 05:19 PM
06MREvo
Oct 4, 2013 05:13 AM
JonMotoring
Evo 'For Sale' Exterior Styling
Sep 15, 2013 03:36 PM
oK-Boi7o
Apr 22, 2012 10:55 PM
