08 Evo X full motor build
After some research the list below is what i have compiled to rebuild my 4B11T. i dont have access to E85, so this will be a 91, or 93 octane build, maybe do a 110LL tune. I'm going to use the car for autocross, and looking for critiques, opinions, and comments on what i need to add or change to this build list before I pull the trigger. I also need a turbo and have no idea what would work best for this.
2008 Mitsubishi Lancer Evo X GSR
157k on body
engine 61k on block at rebuild
transfer case 61k
Transmission 75k
MAP Tubular manifold
3" Map downpipe open dump
3" Hi flow cat
CPE axle back
3" FP Turbo Inlet
ETS intercooler kit
Turbosmart BOV
Perrin EBCS (not installed)
ACT clutch and Flywheel
Aem Wideband
Turbosmart Boost gauge
BC Coil overs
Injector dynamics 1300cc
AEM AFPR
MAP Billet timing chain guide
AMS cam Cap
GSC S2 camshafts
Radium Engineering Clutch fork stop
Manley Billet Stroker Crankshaft
Manley 143.66mm TT I-beam
Manley 86.5mm platinum dish pistons
GSC exhaust and intake valve guides
Ferrea 30mm intake and exhaust valves
Walbro 450 fuel pump
Brian Crower 87mm head gasket 1.1mm thick
King Race main and rod bearings
Mishimoto Dual Oil cooler
Oil feeder control valve filter
OEM oil pump
OEM Oil pump chain
Radium Engineering PCV catch can
Gates Serpentine belt
Mishimoto Thermostat
ACL thrust washers
OEM timing chain
OEM timing chain tensioner
MAP front and upper intercooler pipe
Manley Valve springs
GSC valve stem seals
157k on body
transfer case 61k
Transmission 75k
3" Hi flow cat
CPE axle back
3" FP Turbo Inlet
ETS intercooler kit
Turbosmart BOV
Aem Wideband
BC Coil overs
AEM AFPR
AMS cam Cap
GSC S2 camshafts
OEM oil pump
OEM Oil pump chain
ACL thrust washers
OEM timing chain
First off, what are you power goals, or what size turbo are you looking to run (really still based on power goals)? The EvoX spools turbo's very well with the stock stroke crank, and going to a stroker seriously limits the RPM you should be spinning. As well as the 94mm crank having a terrible rod ratio and it piulls the piston out of the bottom of the sleeve.
Second, I generally avoid Manley products. Especially the rods, they are heavy for what you get. And you're going to need to add sleeving the block to the list.
Yea, need your power goals and also how you plan on using the car (Street, Track, Drag).
Go full GSC. Ferrera has QC issues.
No need for the AMS cam cap unless you messed your OEM one up.
Mishimoto is crap. If you need to upgrade your oil cooler, MAP makes a nice kit with Setrab cooler.
I originally had Ferrea valves down as what I wanted to use but multiple machine shops told me they have seen issues with them and to go with GSC. I dunno, maybe they all had GSC accounts? hahah
Huh. Idk, thats odd. Obviously nothing wrong with GSC either; I've used valves from both both, and I know Headgames sells/uses both as well. GSC is actually a bit less $ on valves too.
FS[Northeast]: NY: Billet 2.1L Longblock *Like New*
MisUnderStood
16
May 17, 2018 07:38 PM
toxic-evo
73
May 18, 2012 11:14 AM
