AYC pump throwing codes
Old Mar 16, 2021 | 09:30 AM
Jordan Gi'Casso's Avatar
Hi, my EvoX MR recently had the ayc service warning light come on.
Evoscan is showing these AYC codes : U0100 , C1290
I cant find any detailed info about these codes, I was hoping someone would be able to tell me what these codes are and how to remedy them if possible.
thanks,
Old Apr 18, 2021 | 08:16 AM
madismts's Avatar
5 Year Member
I have the same issue with my Evo X GSR, I recently overhauled the ACD/AYC pump and bled it and installed with no efect, the lights still come on and it seems no voltage to the pump is received, when ignition on and gas pedal floored. Did you get any help, solution to the problem?
Old Apr 26, 2021 | 10:40 AM
evox39's Avatar
Hello, i have the same problem after changing clutch ! Same code error : U0100 & C1290 but don't find any information about it...
The error correspond to :
U0100 : Engine Control module CAN timeout
C1290 : CAN time out error
But... No solution..
Thank you in advance if you find a solution !
DeepFrz
Jan 18, 2016 07:15 AM
Nega
Jul 25, 2013 12:44 PM
jjgriffin
Jun 4, 2013 03:13 PM
TakaseEVOIXSE
Jul 23, 2007 04:19 AM
Ed Wolfram
May 20, 2007 09:47 AM
