Hesitation at wot
Old Jul 5, 2021 | 06:30 PM
Hickman10's Avatar
Hesitation at wot
Ok i know this has been probably ran into the ground but cant seem to find exactly the same issue. So at wot i get a choking hesitation and runs through every gear but only past 4500 rpms. It seems to get worse the harder i push the car but if it car sits a while and i get on it its not as bad. If im not in boost or light boost i have no issue all the way through the rpm range. I have done a boost test and no leaks were found. Even changing plugs has same issue. Was told my catalytic converter is clogged but unsure of that. Any help would be great. Its a 2012 X GSR
Old Sep 16, 2021 | 03:58 PM
eliruiz's Avatar
Had the same issue to a while back. Found out that the heat was causing the car to hesitate. It during 100 plus weather and stock intercooler. So probably heat soaked and was sucking in warm air.
Old Sep 16, 2021 | 04:11 PM
RazorLab's Avatar
What is your plug gap? 99% of the time it's the plugs
Old Sep 22, 2021 | 04:59 PM
Jaraxle's Avatar
Checking the cat isn't difficult, but do you have any gauges or logging to see AFR, knock, timing, etc?
MRLancer05
Jul 27, 2016 03:52 PM
mohamadaz
Sep 22, 2014 09:07 AM
330awhpevox
Nov 24, 2011 09:20 AM
aguita
Nov 2, 2009 05:30 AM
justchil
17
Jul 7, 2007 07:30 PM
