Another EVO X Misfire
Old Jan 15, 2025 | 03:15 PM
EvoXSeth's Avatar
So my Evo has been misfiring ever since I put a new motor in. When I put the motor in I changed everything. (Turbo, fuel system)
The motor is from Daytona Mitsubishi. It is a FE Long block.
Misfire only happens at idle with no load and only when warm. Cold starts are fine. When AC turns on it goes away.
I have swapped plugs, and coil packs.
any help???
OEM FE Block
FIC 1650cc injectors.
Radium fuel rail with FPR and pulse dampener
MAP 3.5 to 6in intake
Wallabro 450 hardwired.
TPC GT Spec Turbo
STM Open dump.
Old Feb 19, 2025 | 10:46 PM
Rohit Mehra's Avatar
It sounds like a fueling or idle airflow issue, man. Since the misfire goes away with AC on (higher idle), try tweaking the base idle and fuel trims. It could also be injector latency or a weak IACV. Have you checked logs for AFR fluctuations?
AKB_EVO
Dec 20, 2016 05:36 AM
sLUg_
13
Nov 18, 2011 11:29 PM
proracer718
Dec 27, 2009 03:40 AM
baggedtaco
11
Apr 10, 2009 12:59 AM
str8kor
25
Jul 14, 2008 10:55 AM
