Car and Driver Comparo 13.4@103 (MERGE)
IMO the new STi wouldn't look half as bad if:
- It was 3 door instead of 5door hatch
- Got rid of that chrome plate inside the front grille, it makes it look like a Saturn
Also JDM version has 2.0T that revs to 8k and has twinscroll turbo whereas USDM is 2.5T revs to 7k and has single scroll.
If its like Cosworth longblock with aftermarket turbo kit, then of course the 2.5T would be superior (2.0 is restricted engine to be able to enter certain races) but bone stock I'd take the 2.0 anyday.
I assume you are saying this because the person you quoted didn't mention things like wind resistance and object density which essentially determine the terminal velocity of an object (ie, a brick will fall faster than a piece of paper in OUR atmosphere). So, in that sense, he is in error.......realistically though two objects that are sufficiently dense and don't have major differences in their wind resistance properties will fall at the same speed. Maybe then we should give the benefit of the doubt and assume he actually understands the concept and simply misspoke.....rather than jumping to insults.......or you could simply read further to realize that he did in fact make a post that demonstrated his understanding of wind resistance. Granted, there's a lot of nonsense being tossed around in this thread......but some of it appears to be in jest to me.
Now, I'm assuming that you are referring to the person you quoted when mentioning ignorance..........but, if you are in fact referring to the uninformed indivdual(s) that PDXevo was trying to enlighten (and therefore agreeing w/ PDX).......then you can for the most part ignore this post of mine.
KiL
KiL
and they are sooo far away from each other, for set up.Not even funny... just check out the camber on the tarmac car ..
no to mention the tire difference, coilovers , etc.
guzmangjr
Dec 11, 2016 09:05 AM
MitsuRishi
For Sale - Part Outs
Apr 13, 2016 12:18 PM
IX_MR
Aug 14, 2011 09:54 PM
