Sponsored by:
Sponsored by: CARiD
Vortex Generator?
Old Feb 2, 2008 | 08:26 PM
  #31
DirectorSe7en's Avatar
Bump for where we can buy one.
Old Feb 2, 2008 | 08:35 PM
  #32
twentyone's Avatar
straight from mitsubishi or rexpeed
Old Feb 2, 2008 | 11:51 PM
  #33
EmanantEvo's Avatar
Originally Posted by 98autogstspyder
From what I read, the new 10's have something underneath the rear bumper (i forget what its called... some type of air difuser) that makes the vortex generator obsolete. That is why the new models won't be coming with them. Like I said, this was on one of the reports I read.
Diffusers affect the air flowing under the car. Vortex generators affect the air flow seperation over the top of the car. The JDM IXs can be seen with the generators and a rear diffuser. The X either has a better flow over the top with less seperation or the rear wing is not as functional as the previous models.
Old Feb 6, 2008 | 08:09 PM
  #34
Jake26's Avatar
they dont have any for evo 10 yet nor for the lancer 2008
Old Feb 7, 2008 | 01:01 PM
  #35
ViperF16's Avatar
I'm sure you could have the dealer get one for you, but who knows how it work look.
Old Feb 7, 2008 | 03:44 PM
  #36
BambiTLK's Avatar
Pics, please? I just can't picture those spikes on an X...
Old Feb 7, 2008 | 04:12 PM
  #37
AkYap's Avatar
Originally Posted by EmanantEvo
It would be interesting to see if the airflow over the top of the X seperates before the wing as bad as it did on the VIII/IX. Then it could be seen if the generators would be useful or not. Functional or not i think they would still look good on the X.
It all depends on the the angle of the divergent section, in this case the slope of the back window down from the roofline. Just from pictures, you can tell that the X has a smaller angle slope than the VIII or IX, so flow seperation would occur further downstream. Where exactly i cant say, the mathematics of turbulent airflow currently can not be solved with our level of understanding. It will require wind tunnel testing.
What i do know is that previous data on divergent slopes give a rule of thumb of 7.5 degrees of slope in order to maintain boundary layer adehsion. If you place vortex generators in the divergent path, you can increase that slope to almost 13 degrees. Even with this, the flow is not re-attaching to the back window. It is possible that reattachment occurs on the wing itself. But again, i will need wind tunnel data to do any sort of educated specualtion.
Also, given the new angles and dimensions of the X, the vortex generators would also need to be redesigned, i.e. the hieght of the VGs woudl need to be altered to be optimized at a given velocity. This i can do very easily if given the exact dimensions of the flow path from the front of the X to the end of the roofline and a given desired velocity to optimize to.
Old Feb 7, 2008 | 04:16 PM
  #38
Uhh, are you referring to VG's for the Evo X? Last I checked they didn't exist on USDM X's.
Old Feb 7, 2008 | 04:18 PM
  #39
evo8rcr's Avatar
Old Feb 7, 2008 | 07:32 PM
  #40
That's what we're all bumping for, lol.
Old Feb 7, 2008 | 10:29 PM
  #41
ViperF16's Avatar
No one has pics ... so whats the point of even asking? The whole point of this thread to see if it can be done with the x.
Old Feb 7, 2008 | 10:39 PM
  #42
Lancerally_Mick's Avatar
OMG that thread sucks ...
Old Feb 7, 2008 | 11:28 PM
  #43
ViperF16's Avatar
True.
Old Feb 7, 2008 | 11:52 PM
  #44
^+1
God, please let this thread die off.....
Old Feb 7, 2008 | 11:59 PM
  #45
Highwind's Avatar
need pictures
