Sponsored by:
Sponsored by: CARiD
Question about stepper motor boost gauge, DEFI and STRI
Old Feb 15, 2008 | 05:40 AM
racer135's Avatar
Anyone using STRI DSD-SLM II ( Gauges? These are stepper motor driven gauges. I just installed a boost gauge and I notice some tickling on the gauge movement, specialty when the car is idle and the vacuum reads about 18in Hg. The tickling is not noticeable during boost or any other big movement of the needle. I can detect it just when the needle is almost steady and a very small movement is required to make the reading. I know that is the way stepper motors work but it also depends on the needle gearing. Is this normal? Do DEFI Boost gauge does the same thing?
Old Feb 15, 2008 | 07:37 AM
bmx's Avatar
bmx
I think it is normal as i use to have the boost gauge and oil temp as well. Think the gearing aint as smooth as that of Defi or Apexi. Just a soft tinking sound everytime there is a small adjustment.
Old Feb 15, 2008 | 09:52 AM
racer135's Avatar
bmx,
That’s exactly it, a small tickling movement every time there is a small adjustment. Sound is almost unnoticeable at stop and you can’t hear it when driving. Why did you get rid of the STRI gauges? Did you change for other brand?
Old Feb 15, 2008 | 10:35 AM
DirectorSe7en's Avatar
Can you post pics?
Old Feb 15, 2008 | 04:05 PM
racer135's Avatar
I have a video. How do I post it?
Old Feb 15, 2008 | 04:06 PM
racer135's Avatar
Sorry I thought this was the EVO VIII Forum
Old Feb 16, 2008 | 12:08 AM
bmx's Avatar
bmx
i sold off my guages at%
Old Feb 16, 2008 | 12:27 AM
Jameson_IXMR's Avatar
The more accurate the motor, and therefor gauge(depending on transmitters), unfortunately the louder the stepper is likely to be. The more samples per second the gauge takes does not only equal more movement per a given time, but also a quicker momentum for that given needle(and associated gearing system) needed to maintain that given speed. You could have a bad gauge, I have the Defi's and they tick, but slightly, the sound of the air conditioning nuffkes them out, but either way, your going to hear something.
Old Feb 16, 2008 | 04:57 AM
racer135's Avatar
Jameson,
I cannot hear the sound when the car is miving due to other noises. When I say tickling I mean more the movement of the needle is like a clock seconds hand (not really as bad as a clock, the clock is just an example of the ticling in the movement). It is only noticeable at idle when the needle is moving just a lil. Do DEFI does the same thing?
Old Mar 13, 2008 | 05:41 AM
if it is quiet enough yes. like a clock tick
Old Mar 13, 2008 | 07:48 AM
redboosted05's Avatar
yeah i notice a tiny needle movement at idle around 20 vacum
Sir_Lancer_Lots
Mar 22, 2015 09:49 AM
tazdevilxxi
Aug 17, 2009 03:44 AM
scumrat
Mar 30, 2008 05:35 PM
shinnster
Oct 16, 2006 06:20 PM
siQness
19
Jul 27, 2004 09:12 AM
