Is left foot braking in an X still possible?
With the switch to drive by wire, wondering if one can still left foot brake in the X? In most other cars, ECU starts cutting your engine after 2 secs if it detects gas & brake depressed at the same time. Just curious if the X followed the masses for street safety or decided to still allow it.
With the new electronics that everyone raves about, there is probably even fewer places where you'd want to left foot brake in the X....but I'm curious just the same...
Thanks.
Thanks.
Thanks.
Thanks.
To be honest I LFB to kill understeer mid corner on long corners, the car does not understeer there because of the torque vectoring diff (that's why I didn't think to try it). In the dirt though or on a Auto-x it would be potentially useful.
based on what the videos i have seen on best motoring you should still be able to do the usual left foot breaking.
if u need it to eliminate understreer in turns i bet with evo X u don't need to do that since evo x makes good use of its ayc and make the car seem like its oversteering.
I was pretty sure before I tested, but yes, left foot braking is still possible in the X. There is no intervention to reduce power to the ECU with the brakes unless its the stability control. With ASC completely off, you can do whatever you want, including do something stupid like apply throttle and light brake pressure completely through a fast corner (which I just did) and never have the ECU cut power.
Thanks for trying and confirming. I'm not sure I'd call it stupid as this is a good advanced driving technique for certain situations.
VT Mitsu
Nov 8, 2016 11:02 AM
alfonso_meneses
Oct 18, 2016 11:19 PM
Roger350
Mitsubishi TC-SST Discussion
Sep 24, 2013 09:48 AM
