Sponsored by:
Sponsored by: CARiD
AEM TRU-Boost install question!
Old Mar 4, 2008 | 05:20 PM
EvoX_SA's Avatar
I just got my AEM Tru-Boost today and I have it part way installed. I can not for the life of me find a way to get the wires to the engine bay. I have searched all over the firewall with not luck. The only other way I can think of is to drill a hole through the wall, which is my last resort. Any help would be appreciated.
Old Mar 4, 2008 | 05:30 PM
shunderwunder's Avatar
There is a gromet that can be found if you remove the glove box (easy). Search for boost guage installs. Thats how I found it. It is a little hard to get to, but can be done.
Old Mar 4, 2008 | 06:14 PM
PDXEvo's Avatar
Are you referring to a IX or a X shunder? There is no grommet that I am aware of for the IX. I had to drill a hole to get mine through. The best place to do this is where the steering column goes through the firewall. You only have to remove a small plastic piece, and drill. No carpet in the way etc. Be careful where you do it though, as the brake lines are on the other side of that plate, and you will run into them if you go in the wrong spot.
W_evo8's Avatar
+1 use a coat hanger to guide though the gromet hole.
Old Mar 4, 2008 | 06:24 PM
EvoX_SA's Avatar
I just checked every inch of the wall on the Evo X and there is no grommet to be found. I will try to drill a hole where the steering column. Thanks for the help so far I will see if this works hopefully so.
Man did mitsubish put alot of carpet and sound deadener in this thing there is carpet and them under that is more carpet/deadener. It's everywhere I guess that where that extra 200 lbs came from
Old Mar 4, 2008 | 06:29 PM
PDXEvo's Avatar
haha, I know what you mean. Yeah, I couldnt find a grommet either. Fortunately, there is no carpet under the plastic part for the Steering column. Pretty easy actually. I should have just done that first and saved myself 1 hour searching for a place. I drilled a 7/8 in hole, and put a large grommet in.
Old Mar 4, 2008 | 06:33 PM
EvoX_SA's Avatar
Yeah I just removed the plastic piece from the steering column it was really easy. Nothing in the way on the other side, plus right where I need it to be. Thanks quys.
Old Mar 4, 2008 | 06:46 PM
TURBODAWG's Avatar
That is terrible you have to drill a hole in your new car just to pass through the firewall. Surely there is an access grommet somewhere. If not, there can be any add on factory guages with this car on the MR.
Brian
Old Mar 4, 2008 | 06:59 PM
34Turbo's Avatar
There is one on the passenger side on the IX. I ran pretty much everything through there including my 4 gauge power cable for the amplifier.
Old Mar 4, 2008 | 09:25 PM
Evo_Jay's Avatar
I dont know about the X, but the 8/9 DOES have a hole behind the glove box to run wires and boost lines though.
Old Mar 4, 2008 | 11:21 PM
PDXEvo's Avatar
Not there on the X.
jetxjosh
Evo X How Tos / Installations
Mar 12, 2016 05:39 PM
fyreant
14
Sep 12, 2014 02:49 PM
krackerstache
Cobb AccessPORT
Nov 4, 2011 08:46 PM
alpha812
Aug 23, 2011 11:07 AM
