Sponsored by:
Sponsored by: CARiD
TSB 08-13-006 Ecm Reprogramming for dtc 1320
Old Apr 11, 2008 | 08:35 AM
wickedchimp's Avatar
Just ran across this:
Please Sticky
Old Apr 11, 2008 | 08:40 AM
Alexander's Avatar
Nice.
Old Apr 11, 2008 | 08:58 AM
apex_silver's Avatar
e mailing this to my dealer a.s.a.p
Old Apr 11, 2008 | 09:00 AM
zbomb's Avatar
Maybe you should put all these TSB's in the same thread, Does'nt really make sense to sticky multiple threads all on the topic of tsb's.
Old Apr 11, 2008 | 09:02 AM
I chose to do it this way so they can be discussed seperately. If the Mods would like to combine them, they are more than welcome to. This is the only one that is a TSB. The others are TT or Tech talk.
Old Apr 11, 2008 | 11:16 AM
im set for monday. also the stealership i bought it from set me up but are like 60 miles away, i called the one closest to me and they acted like it didnt exist put me on hold and asked what is your car doing ? i read from the list that was posted they made me an apointment on mon i feel basically they were not going to fix it. unless i was getting codes. im going to tell them i want to see proof they did the job. after the treatment i received on the phone. my guess is if they look to see the codes which never happend then they might just say they flashed it. the codes are saved correct ? as i was reading the problems the tech said are these actually happening or are you reading this off the computer lol !!
Old Apr 11, 2008 | 12:28 PM
REDEVO08's Avatar
I just made my appointment to get looked out..They are going to check out the trans as well..
Old Apr 11, 2008 | 12:50 PM
Mojito's Avatar
It does say that the dealers should not reflash unless there is a CEL code and described symptoms.
Old Apr 11, 2008 | 03:00 PM
what are the symptons ?
Old Apr 11, 2008 | 03:59 PM
bump !!
Old Apr 11, 2008 | 04:08 PM
love9sick's Avatar
Prior to 049108, is that the only end that matters. My number between the V and U is not 08...it is 98. What is up? Am I a prior model? I know I am feeling the symptoms.
Old Apr 11, 2008 | 04:15 PM
buffaluphagus's Avatar
yes, that is the only end that matters
Old Apr 11, 2008 | 04:28 PM
EFIxMR's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=338442
Just today our friend came in for a dyno session to see the difference between the original factory tune vs. the TSB reflash. Check the link above to see the difference!
Old Apr 11, 2008 | 06:20 PM
si_to_evo's Avatar
same here mine is 78 between U & V!
Old Apr 11, 2008 | 06:27 PM
gizmotoy's Avatar
Mine is 28... I wonder what that number means.
