Sponsored by:
Sponsored by: CARiD
Did anyone notice when changing their oil?
Old May 20, 2008 | 10:10 AM
R0ME0's Avatar
Did anyone notice when changing the oil on their X that there was no o-ring gasket on the drain plug? Is that how all the X's are? I don't see any leaks from since changing it. Any comments or feedback on this? Thanks!
Old May 20, 2008 | 10:12 AM
blanknotice's Avatar
I noticed it but didn't really think much of it. You're not alone
Old May 20, 2008 | 10:33 AM
R0ME0's Avatar
hopefully no leaks? No leaks on my end so far
Old May 20, 2008 | 10:35 AM
Mightygnu's Avatar
+1
Old May 20, 2008 | 10:37 AM
Nope, nothing so far....
Old May 20, 2008 | 10:38 AM
kimletrim's Avatar
Registered User
Well, it didn't leak before the oil change right? Don't sweat the lack of a washer if it doesn't leak.
Old May 20, 2008 | 10:53 AM
RussellM's Avatar
Plat Vendor
They list an oring in CAPS
MD050317
Old May 20, 2008 | 12:30 PM
machron1's Avatar
LOL wow they really were cost cutting if there is a mitsubishi part number for a drain plug washer that wasn't installed at the factory...
Old May 20, 2008 | 12:37 PM
BlackTrack's Avatar
I did notice. I also noticed mine was dripping after my last oil change. I tightened the drain plug snug, and thought it was plenty tight, guess not. I got it very tight now and no leaks
Old May 20, 2008 | 01:05 PM
RKT SHP's Avatar
well there actually is a gasket there(I bought some filters and gaskets from russell a few months back when they had a special). it is just really hard to get off. it is easy to tell that it is there when you have a brand new gasket to compare to what is stuck on the drain plug....I also just left the gasket that was on there alone as it was extremely difficult to get off.
Old May 20, 2008 | 01:09 PM
Thegame's Avatar
So the X does not use crush washers like the VIII, or does it? If they do, is it the same part number?
Old May 20, 2008 | 01:20 PM
ZeroFighter83's Avatar
There were a few threads on here by people who has done their oil changes already. The original ring is painted and is actually on the drain plug. You either have to pry it off or just get a new plug and ring.
Old May 20, 2008 | 01:24 PM
tsitalon1's Avatar
There is a crush washer clearly listed in the tech manual. I ordered the filters and crush washers from JNZ when I bought me oil chnage supplies.
I bet you guys have a crush washer on your drain bolt and don't know it...it's very hard to see..had to use a razor blade to pry it off the bolt.
Old May 20, 2008 | 06:07 PM
USP45's Avatar
Actually my VIII was the same way on its first change if I remember correctly. I had to cut it off with an X-acto knife as well, I could have sworn that it was not on there until I got it off..
Old May 20, 2008 | 06:17 PM
boostinscooby's Avatar
+1 they tend to blend in!
