Sponsored by:
Sponsored by: CARiD
Those little plastic screw-plugs on the intake...
Old May 30, 2008 | 11:51 AM
STi2EvoX's Avatar
I had this problem on my X as well. All you have to do is reach underneath and apply upward pressure to the bottom of the clip with your fingers while unscrewing the screw from the top. Pushing down in the middle will not work as that will only force the clip that the screw sits in to fan out even wider which is what holds it in to begin with. Another easy way to do this is if you can't get your fingers underneath the radiator support to access the bottom of the clip assembly then you can just try applying upward pressure to the snorkel while unscrewing the screw. All that it needs is some tension on the clip so that the screw has something to squeeze against while it's being unthreaded. Good luck.
Old May 30, 2008 | 07:20 PM
blanknotice's Avatar
I had this problem. I used a small flathead screwdriver. Take it and work it in between the plastic screw and the ring around it. It doesn't even need to be in that much. Push down on the flathead to make the screw come up. Mine doesn't look bad, but you can tell I screwed it up, no pun intended. It will strip the screw (which is probably already stripped). I just shove mine back in there when I want to put it back and use the same method to get it out.
I couldn't get it out by prying the whole thing out, so you're not alone on that. Work on that inner screw.
Old May 30, 2008 | 10:57 PM
ibarkovic's Avatar
you have to unscrew them without putting pretture downwards and they easily come out.
Old May 30, 2008 | 11:03 PM
DVDee's Avatar
I had this problem. I used a flathead and pressed on the rim right outside the screw and lifted it up. It came right out and then I took off the rim.
Old May 31, 2008 | 04:59 AM
MrBonus's Avatar
Thanks, guys. I got it out last night. Now I need to figure out where my boost leak is with my upper intake pipe...
Old May 31, 2008 | 06:36 AM
pitstops's Avatar
you need one of these, super easy to take off.
Old May 31, 2008 | 06:52 AM
edofloat's Avatar
plastic screw...
I suspect you could drill it out like a pop rivet.
Foggy
16
Oct 19, 2011 06:29 AM
tephra
Jun 9, 2010 05:09 PM
09GTSLancer
Lancer How Tos / Installations
22
May 24, 2009 11:24 AM
AzN_Enthusiast
Sep 11, 2006 10:07 AM
tuffguy
04-06 Lancer Ralliart How To Requests / Questions / Tips
Feb 17, 2005 08:23 AM
