Sponsored by:
Sponsored by: CARiD
O2 housing????
Old Aug 4, 2008 | 11:43 PM
Joe's Evo X's Avatar
Bump for any updates.
Old Aug 5, 2008 | 04:44 AM
Dyno4mance's Avatar
Originally Posted by High_PSI
That prototype needs a BUNG for the 02.
It's there, look at the cat end of the pipe. X's 02 sensor is at the cat end of the down pipe.
I was really just bumping this for updates and to add that I think you guys should make this a two piece affair, even if it does not split at the stock location that is a tight working area and you really need to be able to pull the turbo with the 02 housing intack, not sure you would be able to do this with the 1 piece design.
Looks real good though
Old Aug 5, 2008 | 06:42 PM
SiC's Avatar
SiC
Here's one by G-Force Japan, it's a two piece with a slip on joint and flex pipe. They didn't want to use a flange so they can use larger diameter piping (the flange is really close to the steering column on the JDM).
Old Aug 12, 2008 | 10:28 PM
Hiboost's Avatar
Bump for any info on an upgraded O2 Housing or O2 Housing Downpipe combo. What would be involved with installing either one, would the turbo have to be removed or is it just a matter of a few heat shields from the engine bay working from the top?
tscompusa
Apr 25, 2017 01:52 PM
jozef.borg1
Mar 7, 2017 09:40 AM
fishie36
Nov 11, 2013 07:50 AM
Joe's Evo X
Jul 28, 2008 03:37 AM
2StepsAhead
25
Dec 11, 2006 11:50 PM
