Sponsored by:
Sponsored by: CARiD
Meth/water/alcohol injection
Old Jul 22, 2008 | 05:20 AM
Joe's Evo X's Avatar
Check this link out as well and there is a guys named Richard L, He is in charge of the aquamist system on the fourms. He has a post on the link below so you can find him there. So you can hit him up and he will tell you how to order the system. Or you can also pm me as well.
https://www.evolutionm.net/forums/sh...d.php?t=356318
My system should come in today
Old Jul 22, 2008 | 05:40 AM
gotrnet's Avatar
just out of curosity, what type of fail safes are you guys talking about/running? i don't know of anything i would call a "fail safes" on a meth kit unless it was tied into the dual boost set up and if it quit working it kicked it back to the low boost setting. i have a float hooked to mine to let me know when it is getting low and i have an led hooked to the power to let me know when the pump is on (or at least has power) so i have some indicators but if a pump quits working or a line comes loose the only thing i know is to get off the throttle and i use knock for that as mentioned before. this maybe a matter of semantics. so what is everyone else running? BTW, i run 100% meth.
Old Jul 24, 2008 | 01:10 AM
Well for a MBC you can install the MAC valve, or for me i have the EBC i just cut and wire to the aquamist system and what it does if there is a system fail it cuts boost to like 10 psi or so.
Go_Lancer_Go
10
Jan 13, 2012 12:52 AM
RalliartMR
May 2, 2008 05:55 AM
jasburbak
Apr 17, 2008 03:46 PM
Inprogress
15
Sep 25, 2007 05:43 AM
