Sponsored by:
Sponsored by: CARiD
View Poll Results: Which would you choose?
Evo X MR
228
80.28%
Lancer Ralliart Sedan
37
13.03%
Lancer Ralliart Sportback
19
6.69%
Voters: 284. You may not vote on this poll
Evo X MR or Ralliart
Old Oct 13, 2008 | 09:42 AM
  #121
EsRt2evo's Avatar
Originally Posted by STi2EvoX
Hey genius, that dyno isn't a dyno dynamics dyno, it's a "dynamic" dyno which is a totally different brand and reads higher than even a dyno jet, "wiz." Second, the reason that I was quoting a dyno dynamics is because they are the most accurate dynos in the world and it is also what my local shop uses so I was able to give a perfect example of what an EVO X puts out vs what an RA would put out. If an MR loses about 30 % according to a dyno dynamics then so will an RA.
You don't seem to understand how different dynos read very differently. You're one of those peope that looks at a high reading dyno graph of an RA and then compares it to low reading graph of an EVO X on a dyno dynamics and you say, "see, the power isn't that far off so the RA must be underrated!" Different dynos can't be compared! Again, let me try to educate you on this because you clearly don't get it. A dyno dynamics reads a X at 220 whp while a dyno jet will read around 250, and mustangs, although usually low reading, can be calibrated to read higher than even a dyno jet like TTP's showing a stock X at like 260+.
Then you have dynos like the one that XS is using, that you mistakenly thought was a dyno dynamics, and those typically read even higher than Dyna Packs, which usually read higher than dyno jets. You have a lot to learn pal, so in the future when you don't know what you are talking about, try not to fire your mouth off like some punk and try to learn from people who clearly know more than you do. Moving on...
I assure you that the RA isn't being underrated from the factory, that's just wishful thinking from a kid who can't afford an EVO and thinks he can turn his RA into a poor man's MR. Oh and no, for the power to weight ratio of the RA a 14.1 sounds fine enough. A GSR runs a 13.3 stock, so I aint skeered of no POS RA! You my friend, are the only one "rambling on inconclusively" with your naive wishful thinking and blind views with how easy you think it is to turn a WRX into an STi or an RA into an EVO.
As I said many times before, it will be easy to make an RA match a stock MR in the straights but after that you still have an inferior car that will lose miserably in handling and braking and every other category. An RA will never be an EVO no matter what you do to it so just get over it.
Oh, and since you brought up STi owners "coping with modded WRXs," I used to have a modded STi and used to rape modded WRXs all the time so I aint affraid. People like you argue the point that "well, for the price difference it's cheaper to make an RA as fast as a stock EVO than it would be to buy an evo, blah blah, so you EVO guys should watch out." My response... I don't care! Money isn't a factor for me like it is for you so I can afford to buy the EVO AND mod it as well, which means that you will never catch someone like me. Sorry.
How do you even know that guys financial situation? I dont understand where you get off saying the things you just said. Some people like to spend their money elsewhere, maybe invest it, or save it for early retirement? What is your problem? So because Warren Buffet lives in a two story suburban home and drives a Cadillac DTS he doesnt have enough money to buy a Ferrari or Lambo? Just because someone buys an RA does not mean they want it to be an Evo. Get over yourself and your car.
Old Oct 13, 2008 | 09:51 AM
  #122
Mors's Avatar
Ahhh I see. Every dyno in the world is inaccurate if it doesn't suit your argument? does anyone have a reliable dyno other than your neighborhood shop? Where is your basis that the dyno sheet I just provided is wrong, based on your personal experience and vast knowledge of the subject you know for a fact that XS Engineering's dyno is rigged to put up huge inaccurate numbers? I guess we should all believe you after all you've supported your arguments with verified dyno numbers from the RA and the MR on "accurate" dynos.
It's funny how you continue to argue that all these reports are inaccurate, when you still avoid the obvious point that the RA has already run a 14.1 1/4 vs. the MR running a 13.7, even the the RA has SOOOOO much less power and is obviously garbage.
I'm done with this thread.
  #123
STi2EvoX's Avatar
Ugh, I give up. I am saying not to compare one dyno to another. If you want to cite the RA as making 222 on XS' dyno then cite what a X makes on their dyno. What I've been saying is that you are comparing a number from XS to a X from other dynos and you can't do that. The next few months will show you everything that I've been saying anyway so I don't care if you listen to what I'm saying or not. You have a lot to learn but that will come in time. FTR, I am not trying to insult you, but you have taken a nasty tone with me from the beginning and I have treated you with the same level of respect that you have shown me. You don't seem to understand what I have said or don't want to because it proves you wrong, but it's not important. As I've said many times before, the RA is a good car but just don't act like it's gonna be an evo beater. Nuff said.
Old Oct 13, 2008 | 10:00 AM
  #124
SASD209's Avatar
Admin Alumni
All:
Knock off the name calling and other crap. Keep it on topic and RESPECTFUL, please. Thanks
SASD209
Old Oct 13, 2008 | 12:07 PM
  #125
ambystom01's Avatar
Jesus christ, I can't believe how silly some of the arguments have become. I'll start will all the dyno crap, you cannot compare the results of dyno X with dyno Y even if they are the same dyno type. Every dyno reads differently, it's simply the nature of the game. Moreover, the environmental conditions can be different which will change the results. The 220 AWHP may be correct but only for that dyno , on other dynos I guarantee you that the Ralliart will post numbers less than 200 AWHP. An 07 WRX puts down about 170 AWHP and it has the same HP rating. 220 AWHP is about what a stock STI puts down on a number of the dynos around here. Evos put down the same numbers as well.
Second up, this idea that the Ralliart is underrated. Answer me this, why would Mitsubishi underrate the Ralliart when it's competitors are posting higher numbers? That makes absolutely no sense whatsoever. If they're trying to one up the WRX or the MS3 or the Cobalt SS, they're not going to list the performance numbers as lower than what they really are.
Third up, the 1/4 mile times. While yes the Ralliart does post a similar time to the MR, the major reason for this is the AWD. The fact is HP isn't that big of a deal when it comes to getting off the line fast, there is a decreased return as the power goes up. What this means is a 200 HP car will get off the line substantially faster than a 100 HP car but a 250 HP car won't get off the line substantially faster than a 200 HP car. This continues as the power goes up. In the 1/4 mile, the Ralliart can keep up because it's able to stay in it's powerband and it weighs less. However, at the track the MR will absolutely destroy it. On the street, the MR will absolutely destroy it. They are two completely different cars designed for completely different purposes.
As far as suggesting that Evo owners are jealous or afraid of the Ralliart's potential, you have to be kidding me. The Evo is a far superior performer and it will cost Ralliart owners more to make their car perform and feel the same as the Evo than it would to just buy the Evo. The only thing Evo owners need to be jealous of is the ignorance displayed by some people since ignorance is bliss.
Old Oct 13, 2008 | 12:17 PM
  #126
Robevo RS's Avatar
i have to put in here, i love the RA idea and i'm very happy the Mitsubishi came out that model.
It think it was a too big gap between the Lancer and the Evo, almost like those cars came out from two different company. RA will fill that gap nicely.
Only thing is really bugs me when the RA owners cut you off on the street and start posing ....
I mean...
Not to mention to start arguing on the EVo performance. I would see they faces when they got questioned from the GTS owners about they performance and price vs the GTS..
Looks like we have to go the same road that the Impreza drivers did..
Sadly we didn't learned from others mistakes. Just like the WRX owners want to prove they smart buy over the STI owners. As long as you are a proud RA owner everything is fine. But when you start questioning the Evo, and the performance , it is looking weird i can say at least...
But its oke , as higher you go the bigger you fall.
Old Oct 13, 2008 | 02:51 PM
  #127
STi2EvoX's Avatar
People don't understand that dynos read differently or understand what ambystom was saying about how launching two cars that are 50-60 hp apart isn't going to make for huge differences in 0-60 times. They also don't understand that a half a second difference in the 1/4 is a huge difference visually, as that will be the difference of several car lengths.
Mors, I am not trying to be insulting, I'm really not. Matter of fact, I would like to apologize for being a bit abrasive with you. You just have a lot to learn I think, because judging from your comments it's pretty apparent that you are somewhat new to performance tuning and don't have enough firsthand experience with building and modifying cars to know what kinds of limitations certain setups can have. We all have to start somewhere man so it's all good.
My point about all the dyno stuff was that XS' dyno is very high reading, and that's fine but you didn't care to include what a stock X makes on THEIR dyno but rather compared it to what you have heard X's make on other dynos. When a X dynos on a low reading dyno like a dyno dynamics and shows 220 whp you can't compare the two and say that they are close in HP and that the RA must just be way underrated. The fact is that a X on XS' dyno will most likely make somewhere in the neighborhood of 280 whp.
It's all relative to how that dyno reads and that's all that I was trying to say. I think that what I was saying went over your head and you though that I was just discrediting the RA's potential which I promise you is not the case. I think the RA is a good car and fills the void of not having a WRX competitor in mitsu's lineup. It is, however, a WRX competitor and will never be competitive with the STi or EVO without lots of money that in the end would've been better spent by buying an EVO to begin with. I hope that you understand what I am saying now and I hope that there's no hard feelings.
Old Oct 13, 2008 | 03:42 PM
  #128
Mors's Avatar
No hard feelings, I'll leave this thread where it is. While I don't own currently own an EVO, I own a few cars that I've built by hand myself (69 GTO RA3 400, Integra DA B20/VTEC ~200 whp NA) so I do know a thing or two despite your best guess. It was my mistake turning this into an EVO vs. RA discussion, when really I'm just interested to see the potential of the RA in the hands of the various distinguished tuners in the Mitsubishi community
Old Oct 13, 2008 | 07:07 PM
  #129
Robevo RS's Avatar
it has a potential, but the main drawback on it is a SST. As its stands right now.
If the RA would be a MT then i would agree with you about the straight line performance and value . For those who interested in Drag racing and rally the MT RA would be a gift from Mitsubishi.
But would be still the junior on road racing, or on the super stages in rally.
Old Oct 13, 2008 | 07:40 PM
  #130
Eurorcr's Avatar
Evo X MR FTW
Old Oct 13, 2008 | 09:16 PM
  #131
dboz's Avatar
Good points, but cars are now often underestimated by the factory ever since the Ford Cobra 300HP debocle. Better to state and be over than state and be under. That creates lawsuits.
Old Oct 14, 2008 | 04:40 AM
  #132
kaiwang's Avatar
X Mr
Old Oct 14, 2008 | 09:27 AM
  #133
redleg225's Avatar
deleted
Old Oct 14, 2008 | 09:33 AM
  #134
redleg225's Avatar
I like how there's an actual fight now between Evo fans and RA fans because of the claims that the RA can achieve the performance of the more expensive Evo without spending as much.
Before the 09 RA was announced, there was no arguing about whether a RA can ever be in the performance realm of an Evo regardless of the money invested. No one denies that Non-Evo Lancers were slow garbage even if it was a "mighty RA."
NOW, there's actually an argument about the better buy. I think that's an indication of the RA actually rising to a new level. A level where there's a closer gap between it and the Evo. Looking at this thread, it's apparent that Evo owners feel threatened by this.
I, however, don't feel threatened at all. I'd like to see the RA become a car that with less than the price of an Evo you can outperform any Evo in any arena. Unfortunately I think this will never happen. While the gap between the RA and the Evo has gotten closer, it's not enough. The bottom line is that for someone looking for all around performance, the Evo, like it's always been, is hands-down a better buy.
Emphasis on "all around performance" though. While it MIGHT be likely in the near future to spend less than what an Evo costs on a RA + mods and get more straight line performance, you can spend less than what a RA costs on a Kia + mods and go faster in a straight line. Seriously you can.
So again, don't give me that crap about you RA beating my Evo because 1) You spent more on your car and mods than what I spent on my Evo and 2) It's still not on-par with it on all around performance. Great job numb nuts, you could be driving an Evo right now.
/rant
Old Oct 14, 2008 | 02:45 PM
  #135
Robevo RS's Avatar
/rant
" Looking at this thread, it's apparent that Evo owners feel threatened by this."
You are completely miss under stood that. I'm insulted. Why? Because they questioned our value over they.... Which is insulting at least.
Threatened... Are you serious?
about the RA straigh line performance , first of all it is looks like limited around 350 wtq and whp. And missing the racing mode from they tranny. So how far you can go with that?
Just a cat back and the drop in filter + tune i got dangerously close to that...
