Sponsored by:
Sponsored by: CARiD
View Poll Results: Which would you choose?
Evo X MR
228
80.28%
Lancer Ralliart Sedan
37
13.03%
Lancer Ralliart Sportback
19
6.69%
Voters: 284. You may not vote on this poll
Evo X MR or Ralliart
Old Oct 8, 2008 | 06:15 PM
  #61
strife's Avatar
Evo MR, if your going to try and make the Ralliart faster/better.
EVO FTW!
Old Oct 9, 2008 | 07:07 AM
  #62
EvoG8r's Avatar
Can I add the choice of 09 WRX because I can't afford MR and the R/A handles/brakes like crap.
Old Oct 9, 2008 | 01:22 PM
  #63
Robevo RS's Avatar
the 09 WRX should be faster then a X MR... since they tested it with the Cobalt SS and beats the SS on track. Now in other tests the SS beats the X MR..
OOHHHH i LOOOve Those great independent test results
WRX beats SS on track
"quicker than the Cobalt SS and the Ralliart"
http://www.roadandtrack.com/article....rticle_id=7106
SS beats X MR track
"Quickest of those behind the Cobalt was the Mitsubishi Lancer Evo MR, "
http://www.caranddriver.com/reviews/...re+page-9.html
Old Oct 10, 2008 | 11:28 AM
  #64
HudsonFalcon's Avatar
I would have to go with the majority and say go for the MR. If you can afford the Evo experience then why settle.
Old Oct 10, 2008 | 04:58 PM
  #65
AWD Ninja's Avatar
Originally Posted by nawaz
This isn't an option on this thread, but I would choose an Evo X GSR in base trim.
mee toooo GSR FTW
Old Oct 10, 2008 | 09:47 PM
  #66
nine's Avatar
MR !!! ......... 300 whp fo life FTW! or Limp mode every day if you go past 300 whp. GSR fo tha ***** fackin click !
http://www.youtube.com/watch?v=OL4I6_XibHU
Old Oct 10, 2008 | 11:31 PM
  #67
ashyking's Avatar
very similar to wrx/sti
Originally Posted by evolution_X_GSR
Can't believe this is even a discussion. X MR FTW... In the end the Ralliart is not an Evo... so it comes down to taste and how much you are welling to $$$$. Just like a WRX & STI.
i agree. many people buy a wrx and spend $ to replicate the performance of an sti.
the only problem is once you do that, you have no warranty in many cases. the same may happen with the ralliart/mr issue.
Old Oct 11, 2008 | 12:46 AM
  #68
STi2EvoX's Avatar
Originally Posted by silex
Like I said, is there any other reason besides money that is driving (no pun intended) you guys? I love the styling of the RA Sportback so I'm personally waiting for that. The X MR is great, but assuming the RA can be upgraded with X parts it's a moot point. The only parts someone probably wouldn't change is adding in S-AWC and the quick rack pinion steering. The IX's AWD system is nothing to sneeze at. Lest not forget the RA weighs 165lbs less than the MR as well. So it kind of lives up to its name of "Evo-Lite."
I totally agree. I think the best point to make is that one can not be wrong with either choice. Getting an Evo engine in an RA is awesome enough as is stands. The biggest hump I can't get over is if the SST will ever be programmable to at least add launch control and a Super Sport shift mode like the X MR has.
Dude, the differences between the two cars is more than you realize. The AWD system on the ralliart is a lot more than just a missing AYC, it's ALL OF THE DIFFS, front, center and rear that are all different. The center diff isn't even an active type, it's a standard clutch pack type. Moving on, the suspension setup on the X isn't just stiffer, it's layout and geometry is entirely different and can't be used on the narrower track ralliart. You would have to push the wheels further out, which means that you would need the front fenders and rear doors, and rear fenders of the evo to fit them. Plus, you would need the front and rear axles too since they are longer on the evo. Moving onto the engine; despite what the OP said, the internals of the ralliart are NOT the same as the evo.
Subaru put much stronger internals in the STI then what's in the WRX and I guarantee that mitsu did the same. It wouldn 't make financial sense to put stronger, more expensive internals than what the engine needs. Then you have the fact that the tranny is a handicapped version of the SST and well, I don't think I have to make my point anymore. There's a reason that the EVO costs 10k more, and if you were to order and install all of the parts needed to convert a ralliart to an EVO you would spend 20k in parts and labor!
That's like the old joke with body shops, that if you look at the cost of replacing a door, a bumper, etc and you were to piece the entire car together based on parts costs and labor to install them, a 15k civic would cost you about 150k! Anyway, if you are looking for a lancer that's a bit more sporty than the base model and don't plan on doing much modification, then a ralliart is for you. If you want a race car with big potential from modifications, get the evo. Just remember, you need to get that "evo-lite" crap out of your head and realize that like road and track says, "it's more of a maxi lancer than a mini evo."
Car and driver also made a similar comment and here is a direct quote, "Is the Ralliart a cut-price Evo? Actually, it’s more of a Lancer in lipstick." Sorry man, but it's just the truth. I am not trying to rain on your parade, but if you can't afford an EVO and get a ralliart make sure you realize that it's never gonna be an evo. Realizing this now will save you lots of money in wasted mods in the future. Again, not trying to be a dick, I'm just trying to make you realize the truth and to try to better educate you on the REAL differences between the 2 cars. Good luck with whatever you end up purchasing. BTW, here are links to road and track's review of the car as well as car and driver's.
http://www.caranddriver.com/reviews/...take_road_test
http://www.roadandtrack.com/article....rticle_id=7103
Old Oct 11, 2008 | 02:56 AM
  #69
Mystique's Avatar
SS beats X MR track
Then that means the 2009 WRX is faster around a track than the STI.
Old Oct 11, 2008 | 03:19 AM
  #70
BocaShula's Avatar
EVO all day every day even on Kwanza.
Old Oct 11, 2008 | 05:01 AM
  #71
Robevo RS's Avatar
and the Evo MR and the GSR since faster then a Cobalt SS.
Old Oct 11, 2008 | 08:56 AM
  #72
STi2EvoX's Avatar
They never tested the GSR on the track against the cobalt, Rob. The GSR has been shown to be faster than the MR in many tests because it's lighter and stiffer sprung. Anyway, the evo, as you should know, is the far superior car to the cobalt or wrx. The MR is just slow in a straight line in stock form and that's the only reason that it was so close in lap times with that POS cobalt; because the test track in that test had long straights.
In terms of handling and braking there's no comparison. Plus, the cobalt was actually slower than the evo in road and track's test, remember that. It was only car and driver that showed the cobalt to be basically tied, and even then it was only like 1/100th of a second faster. Also, I assure you that the WRX is not faster than the STi, subaru woud not allow that. Not only that but the EVO is already proven to be faster than the STi, so I think that you're misinterpreting the test results.
Most importantly though, the WRX is not faster than a Cobalt SS and certainly not faster than an EVO around a track. In this test all they did was the usual 0-60 and skidpad, and they ran the cars on an AUTO CROSS, NOT A ROAD RACE COURSE. That's why the WRX beat the cobalt, because of AWD. On an auto cross the EVO would crush and embaress a cobalt SS or a WRX, so again, I think you're not really interpreting the facts correctly here.
Old Oct 11, 2008 | 10:20 AM
  #73
DocCola's Avatar
You didn't say money was a worry, so I would say MR is the option.
Old Oct 11, 2008 | 11:02 AM
  #74
Dr. Ev0L's Avatar
i drove the raliart yesterday and its really nothing compared to the evo. i like the interior/extier, but same feeling i get from an evo is just not there. plus its wayyyyy overpriced. here i can pay 3gs more and get a evo gsr. or a used evo for less.
my 2 cents
Old Oct 11, 2008 | 11:22 AM
  #75
toolapcfan's Avatar
yes they saying is much more rigid and i believe it, although you dont feel it. just drive the IX and hop in the lancer and take it around ....
Then get out from the car and say it in honest face , yes it is more rigid and i feel it.
So what i'm saying is, wont matter how much more rigid is the lance body , the driving feeling in the car is not even close /i'm not talking about power/
I'll be the first to agree that how a car feels on a daily driven basis takes precedence over how the car is actually performing. My '93 Sentra SE-R is a lot more fun to drive on the street than the X in a lot of regards. However if you're tracking the car, how it feels goes right out the window. Just because a person can't feel that the X is stiffer than the IX won't translate into the X performing less. My X felt slower with the ACS on than when I had it turned off, but the difference in my lap times were quite significant.
