Turbomagazine X
Turbomagazine X
I just find this article. So it is might be a repost, but i find some really interesting things . As far as i knew, this was an opposite and devolved from the previous versions of evos. So that is why they called the X is a not true evo anymore. I will do soma example what i mean. everytingh is in " .." that is what i used to get from as a draw back.
- this is what the article said:
1/ "4b11 can't hold more boost"
-The Evo X will have an ignition coil for each of its four cylinders, as opposed to the twin-coil system used on the Evo IX, where two cylinders shared one coil. This time around, the cylinder head and block use separate cooling chambers, resulting in more reliability and importantly, less mess when you turn the boost up too high.
2/ " the turbo is not as good as the IX"
-turbocharger Mitsubishi has yet to offer on the Evo. This one's entirely aluminum-oh, and titanium. It's still based on a TD05H, but this one's called a TD05HA-152G6C-12T. A big part of the reason it's in place is the higher compression ratio of the new engine (9.0:1 compared to 8.8:1). For those nerdy enough, the Evo IX used a TD05HRA-155G6C-10.5T, and the Japan-only Evo X RS uses a TD05H-152G6-12T. That RS turbocharger has an Inconel turbine wheel (as compared to the titanium-aluminum wheel we just mentioned).
3/ "too much electronics make this one a not true Evo anymore"
-That's because historically, each new Evolution has essentially been the technologically improved version of its immediate successor.
-Head developer Ryugo Nakao says, "...to date, the main thrust has been how fast we can make them [go]... But in our view things have now changed. Today's new generation of super high-performance machines need to deliver more than absolute speed; they have to wrap that speed in safety and in comfort."
4/ "turbo is in the back... what mitsubishi thinking??? "
- On top of that, it's aimed the other way around, with the turbocharger against the firewall and the intake on the radiator side. This allows for a 10mm lower engine mounting position (the exhaust doesn't have to go underneath it), which results in a lower center of gravity.
-On top of that, the downpipe, which is much shorter, is now 65mm instead of the Evo IX's 60mm pipe.
If some one didn't read it yet here it is.
http://www.turbomagazine.com/feature...n_x/index.html
No fight, just observations
I believe the OP was arguing why the X is a better car, in not the greatest english perhaps. I think he is pointing out the major differences from the IX to the X, while at the same time explaining why those difference arn't bad: better engine design for cooling/longevity, better turbo, better electronics, and better motor position.
So if the old one did 0-60 in 11.5s then the new on must do 11.5s of better but also handle better.. especially when your target market is guys who are "all about the performance numbers" - those numbers must all look better.
That is all fine but the newer car must be at least as fast as or faster than the one before no matter what handling improvements they make.
So In Japan and EU at least , people buy the Evo because the possibilities ant not the actual factory performance.
Talking about bad factory performance... If the JDM or AU -EU EVo IX would be sold in here, then they would be a "worst Evo ever " "The End of the Evos" etc. But its not...
Example:
in Australia the EVo IX 0-60 mph is 5.7 sec. vs us spec Evo IX 0-60 4.5 sec.
au site
http://www.webwombat.com.au/motoring...o-9-review.htm
us site
http://www.motortrend.com/roadtests/...ecs_price.html
The 1/4 mile run ONLY interested in US. IN EU and other parts on the world the people know there is more then 1/4 mile.
The fact matter is the EvoX is 0-60 5.4 sec... so in EU standards not that shabby
Fact in AU the X is faster then a IX ... runs 5.5 sec to 0-60 mph
http://www.drive.com.au/Editorial/Ar...rticleID=43983
^The X averages around 4.9 0-60, not 5.4 dude. The initial test from motor trend or whoever it was recorded that when they had a pre-production model that had serious misfiring issues with the overly rich condition that was vastly improved by production. Granted, the X's still have issues with being overly rich, but it's nowhere near as bad as the pre production models.
The fastest 0-60 time was recorded by, I believe, car and driver, and they got as fast as 4.6 seconds. I know that you're trying to show how the X is a better overal car, and it is, but your first post made it sound like you were bashing it because of your english (which you have got to work on bro, no offense.) Either way, I agree that the baseline numbers don't matter as much as the hardware and platform potential, which are phenominal in the X.
The fact matter is the EvoX is 0-60 5.4 sec... so in EU standards not that shabby"
because im talking about the EU / European Union/ Evo
and said :
"in Australia the EVo IX 0-60 mph is 5.7 sec. vs us spec Evo IX 0-60 4.5 sec."
even i posted the link for 4.5 and the 5.7 sec test for the different Evo's /EU vs US/
as an example the Evo X is actually faster out side in US, then the evo IX.
SO my point is if you go by factory performance numbers with the Evo then you have no idea what is the EVo all about.
I'm not blaming any one here , just i'm saying the rally world is too far from here
Hmm, I read the OP without a problem. I knew what he was saying after reading the first bulletin. So, I wouldn't say his English is that bad, sure it could use improvement, but hell, there's a lot of native English speakers that need improvement.
As for the post. I agree with all the points.
Also, ExcessLancer, there's another thread on this site that shows the stock X outperforms the Stock IX. It's some Italian magazine review.. Was a good read.
Edit: Here's the review fwiw https://www.evolutionm.net/forums/sh...d.php?t=366934
I try to learn the language, but it is really hard for me. My native language is so rare, is not even funny. And for me the grammar and so on , is totally up side down compere to my language.
It is no excuse i know. Seems to me who want me to understand they do.
Some times easier to attack for the poor English then prove your point./ Not in this thread , so no offense/
Robevo RS, I always appreciate your posts. Your rally and road-racing experience always add fresh insights. And I know your English is much, much better than my Hungarian (your native language if my memory is right; please feel free to correct me), since my knowledge of Hungarian is non-existent!
I just have many times different ideas then others. Some times i'm right some times i dont. Here is the place / EvoM/ easy to correct me if im wrong, And i can learn more.
Many times people tend to be dont like it, when i ask them for proof over my opinion.
I like facts, those are the ones really change my mind
Thanks again.
I appreciate any well informed and developed opinions and contributions you want to share. If proper English were required on this forum, it would be a pretty barren landscape. Great article find, very interesting technical specs I had to research to understand. I'm amazed at the evo cannibalism. It's not like they took a **** and called it the evo X. Change got me to consider the evo because I disliked the old body style. It's a personal preference, don't hate. There's plenty of people that think I now own one of the ugliest cars on the planet. Fact is it's an amazing piece of machinery that we're only beginning to understand.
boomtown
83
Feb 2, 2022 03:58 PM
jarkko
10
Oct 2, 2008 04:47 PM
Whooopasss
Jul 5, 2004 10:52 PM
