Sponsored by:
Sponsored by: CARiD
check engine light problems
Old Nov 3, 2008 | 06:08 PM
cweav's Avatar
Angry check engine light problems
I have had my evo x for 4 months and my check engine light has come on 4 times. The first time it came on the scan tool said manufacture specific code, so I cleared it. Then it came on again so I took it to the dealer, they said it was a timing code that they had never seen, they cleared it and said "it should be fine". And it was for about a month so I went ahead and installed my agency intake, but now it has come on again. I am so frustrated! Any ideas?
Old Nov 3, 2008 | 06:13 PM
btownsoccer22's Avatar
dude take it to auto zone and get the code pulled. FREE I took it to mitsu and they charged me 80 bucks
Old Nov 3, 2008 | 06:17 PM
Dr. Ev0L's Avatar
you dont know the code number do you?
Old Nov 3, 2008 | 06:20 PM
evojanoy's Avatar
Does anyone know how to clear the light after you put a test pipe in it?
Old Nov 3, 2008 | 06:21 PM
evojanoy's Avatar
What kind of modifications do you have on the car?
Old Nov 3, 2008 | 06:23 PM
to clear the CEL light by yourself...I just unplug the battery
Old Nov 3, 2008 | 06:24 PM
cweav's Avatar
I only have the agency intake with suction pipe
Old Nov 3, 2008 | 06:26 PM
cweav's Avatar
no I don't know what number it was, I pulled the negative off hoping that will fix it...
burninrubb24's Avatar
there 2 ways to keep the light off after u put a test pipe in do u want the cheap way or the more expensive way
Old Nov 3, 2008 | 06:28 PM
and u dont have to disconnect the battery to clear the light. all u have to do is remove the 2 pcm fuses in the underhood fuse panel with the ignition on engine off for like 10 seconds and then reinstall the fuses
Old Nov 3, 2008 | 06:29 PM
I think the cheap way = antifouler
AM I RIGHT??
Old Nov 3, 2008 | 06:34 PM
evojanoy's Avatar
What does an Antifouler look like and what is the more expensive way. If you can also what is the difference taking the money out of the equation between one and the other performance wise.
