Sponsored by:
Sponsored by: CARiD
Any TIPS on storing a car for 1 month?
Old Nov 25, 2008 | 07:21 PM
Dr. Ev0L's Avatar
4 months i would pump the tires up to 50psi disconnect the battery, gas on empty, and keep it indoors.
Old Nov 25, 2008 | 07:27 PM
boostedwrx's Avatar
Dont put it on stands, it's actually bad on the suspension to sit like that for a long time. If it's only for a month don't worry about it.
Old Nov 25, 2008 | 08:13 PM
aftershock141's Avatar
Empty, or could I just use fuel stabilizer?
Old Nov 25, 2008 | 08:19 PM
Dr. Ev0L's Avatar
ya sure. fuel stabilizer will work fine.
Old Nov 25, 2008 | 10:10 PM
That's what I figured. Now should I change the oil also when taking it out of storage?
Thanks.
Old Nov 25, 2008 | 10:14 PM
AJsGenerX's Avatar
Fuel Stabilizer
Old Nov 26, 2008 | 10:54 AM
icrnk's Avatar
Thanks.
I thought a full tank of gas was better because a full tank accumulates less condensation (water and resulting rust). Also, should you run the car for a bit after adding fuel stabalizer so that it gets through the fuel system?
On the oil, is used oil more prone to become acidic as it is dirty? Regardless, for only a month it's probably not a big deal but for long term I believe it's recommended to do an oil change before and after.
Latitude
Aug 18, 2006 01:43 PM
jeddi
Aug 12, 2004 02:32 AM
