Sponsored by:
Sponsored by: CARiD
Why does the snowflake stay on all the time?
Old Nov 25, 2008 | 02:43 PM
sl0ev0's Avatar
dont worry about it if your #1 concern is horsepower... the a/c automatically cuts out when your WOT anyways.
Old Nov 25, 2008 | 02:55 PM
John83's Avatar
Originally Posted by ddawg1130
your cars are already set then the way that i mentioned above. the default setting should have the ac on most of the time. This is for the reason I mentioned above (AC dries out the air which prevent fogging). last night it was 33 degrees and the car was parked outside for several hours. I have everything on automatic with the temperature set to ~73. I turn on the car and the AC is on.
He wants his car to function the way you mention. However, that is not the default and should not be the default.
This guy is right. Even though it is anoying, its probaly doing what its supose to do.
OT... which reminds me; now that its cold and i have frost on the windows... the vents dont catch the bottom corners of the front window very well :-/
Old Nov 25, 2008 | 03:09 PM
dek0026's Avatar
i really don't have this issue/experience.
i have everything out of auto and the vents set to circulate the air from the outside and the snowflake do not come on even at 65. i think the real main thing is if the vent is set to circulate air from outside or within the car.
Old Nov 25, 2008 | 03:43 PM
gizmotoy's Avatar
The main problem is that you're running the AC and wasting gas. If the conditions are right for fogging, I'll start to fog up my car 2 or maybe 3 times over the course of the 5hr drive to visit my parents. The AC would run that whole time if the I let it, or I could run it for 5 minutes or less a couple times. Obviously, it's intended for people who don't understand how AC works and can help when a car fogs up. This is admirable, but you can do a better job manually.
Fortunately, as others have mentioned, it can be bypassed.
Old Nov 25, 2008 | 03:48 PM
John83's Avatar
i agree. its not perfect, but i think its the intention of defoging..heh.
Old Nov 25, 2008 | 07:21 PM
zebekias's Avatar
Originally Posted by Parikh1234
On my HVAC controls, the snowflake is always on (i keep the blower and air selects on auto and only use the temp control). The snowflake (i presume AC) is always on UNLESS i put the temp to the max. I can turn it off manually but it annoys me that it wont turn off the AC to save fuel and, more importantly, but a couple of HP back to the wheels.
Any ideas?
My Lexus GS430 does it too by default in fully auto mode. It keeps the windows from fogging. I usually manually override it and turn the A/C off. Occasionally, depending on temperature and humidity the windows will fog, so I put it back on auto mode and they clear instantly.
So I'd say Mitsu did this by design.
MrHouse
Jun 25, 2014 02:32 PM
jmacman12
Mar 13, 2013 01:34 PM
tjmhillz
Jan 10, 2008 09:28 PM
xphillipjrx
Aug 4, 2007 07:46 PM
