By pass SRS for after market seats?
Same as title? Has anyone successfully bypassed the srs for aftermarket seats yet? I remember seeing a shop car install the Recaro Ralliart seats which came with JDM bypass but that didn't work for the USDM one.
Does anyone know if someone is work on a bypass as well?
Thanks for the input guys.
I haven't seen anything yet. What I am hoping is when EcuFlash hits the market, someone can put in some time to search for the coding associated with the seats, and maybe cancel them out. That would be awesome.
Thanks Logan for the reply! I want to throw in my bride gias in the car already.
I actually found the vendor I mentioned above. It was E-Autosports. They posted that the JDM bypass doesn't work. Also they do have aftermarket hub, quickrelease, and steering wheel but they claim that it didn't throw the light. I also have the same hub and quick release on my 8 and it didn't throw a light. (Well I think i have the same hub and quick release.LOL :P )
that would b the only solution is 2 throw in a resistor, but the problem is no1 has tested the resistance 4 the X
because from wht i hear if u put in the wrong resistance 1. the light will still b on or 2. ur airbags will deploy
so no1 has tried 2 put a resistor in their car yet, or even test for resistance =\
until some1 decides 2 find resistance were all stuck with the SRS light both regular lancers and evo =\
im pretty sure the resistance used in an STi is different then in an X
in other cars most tuners just take out the light bulb, but considering our cars have that screen that shows the SRS thing anyways, doesnt due much, thats just hiding the problem not solving it, and the subaru crowd all have resistors 2 trick the system
all were waiting for is some1 2 test for resistance, i mean once u find the right resistance a resistor isnt 2 hard 2 build, all u need 2 do is solder
im sure thats how they do it, is take a voltage meter and test for resistance at the chair connector, then go 2 a radio shack and buy a resistor and make it, but no1 has done it yet =\
The problem isn't the SRS system itself according to e-autosports.
The current JDM bypass will only work on SRS system. The problem is there are two other sensors under the seat. There is a slider position sensor under the driver side and there is another weight sensor under the Passenger side. Those sensors don't take the bypass pill. So technically 1 sensor down you need two more to bypass.
