Sponsored by:
Sponsored by: CARiD
those with interior sport package
Old Dec 14, 2008 | 01:47 AM
trexxx8739's Avatar
Just curious if this is happening with anyone else.
I noticed with the weather getting much colder outside my shift knob spins effortlessly until the interior of the car heats up then it locks in position. Is anyone else having this problem? I would think it would be more likely to happen when warm and stick when cold not the opposite.
Old Dec 14, 2008 | 04:59 AM
ibognar's Avatar
Hot or cold,
I'm pretty tight.
Couple of drinks...different story.
Old Dec 14, 2008 | 05:58 AM
gsr0801's Avatar
That is a weird problem. That hasn't happen to me yet.
Old Dec 14, 2008 | 06:14 AM
damen's Avatar
mine does the same thing, now that you mention it
I actually had the knob come off entirely on a particularly cold morning while shifting
Old Dec 14, 2008 | 07:44 AM
rogue's Avatar
Is it and issues that some locktite could fix?
Old Dec 14, 2008 | 07:49 AM
switchblade906's Avatar
i would never do that b/c it would be so hard to get off.
Old Dec 14, 2008 | 07:57 AM
sl0ev0's Avatar
there are different strengths of loctite. if you dont see yourself changing your shift knob anytime soon then using a weak one would be a good option.
Old Dec 14, 2008 | 08:04 AM
rogue's Avatar
Sorry i was not more clear... Check you local auto shop, they should have some.
Old Dec 14, 2008 | 08:05 AM
EvoX2NR's Avatar
I have the same problem here too
Old Dec 14, 2008 | 08:06 AM
Thegame's Avatar
I figured there would be issues with this part. The old VIII aluminum shift knobs had the enblem fall off. That wasn't a big deal compared to this. I guess I'll be counting down the days till mine breaks apart.
Old Dec 14, 2008 | 08:19 AM
scottatyamaha's Avatar
Mine when cold makes a vibrating noise at high rpm.
Old Dec 14, 2008 | 08:55 AM
John83's Avatar
there aren't any threads to be putting locktite on. the shift knob came unglued from a plastic thing inside because the aluminum shift knob or the PLASTIC piece inside expands and contracts like CRAZY.
ever since it started getting cold, this topic has been brought up a bunch. i wonder if theres anone who doesn't have this problem in cold temp areas. i'd get another one from the dealership, but i feel like its going to just do the same thing. maybe use a low temp glue? or a different shift knob.
Old Dec 14, 2008 | 11:05 AM
Rguy's Avatar
I dont have this problem....yet..
Old Dec 14, 2008 | 11:41 AM
Dakoop's Avatar
It sucks when it is cold, the darn thing spins all over the place. I guess at least mine isn't coming all the way off like some other ones. It really sucks when it heats up and stops moving and the emblem isn't straight any more! Drives me nuts!!
Old Dec 14, 2008 | 12:10 PM
John83's Avatar
it was probably in the low teens when i took that pic...at temps like that (for me) its 100% loose.
