Sponsored by:
Sponsored by: CARiD
ETS Exhaust Questions
Old Dec 16, 2008 | 03:04 PM
JDW1479's Avatar
I have been looking at exhaust systems for a while, comparing, listening, looking etc. The ETS exhaust has caught my eye, but I have some questions regarding the system.
1. I noticed the exhaust system uses various types of clamps. If I do go with the ETS, should I just get the exhaust welded together instead of fiddle farting around with clamps cause I know clamps can ultimately lead to exhaust leaks?
2. Hows the sound inside the car? Drone? Is it annoying?
3. Is there a big performance difference between the magnaflow and the ETS merge collector?
4. Whats the weight savings over stock?
5. If anyone out there has the exhaust, what are the pros and cons you have experienced?
Thanks in advance!
Old Dec 16, 2008 | 03:53 PM
switchblade906's Avatar
i have it and i love it.
ETS has GREAT customer service too
Old Dec 16, 2008 | 04:29 PM
JDW1479's Avatar
^ Did you end up welding it all together or are you still using the clamps?
Old Dec 16, 2008 | 04:39 PM
URBANRCR's Avatar
I don't have a X but i did install the system on my friends car and have ridden in it a number of times.
1.A: The clamps will work fine and if tightened down correctly will not leak,but you can always weld everything together if you want.
2. No drone and its actually not very loud inside the car.
3.The merge collector i really don't know give ETS a call.
4.It does weigh quite a bit less than stock but i didnt weight them both so i cant give you the exact weight.
5.It sounds great,fits perfectly,great quality,and ETS has great customer service. you really cant go wrong with this system.
Old Dec 16, 2008 | 05:00 PM
still using the clamps but i might weld it together
Old Dec 17, 2008 | 01:05 PM
Dakoop's Avatar
1. A lot of cars use clamps. If done properly they won't leak.
2. Exhaust is louder at lower rpm. Only time I don't like it is when stuck at certain speeds, 60mph comes to mind, it gets kinda loud and annoying.
5. I like the sound and the performance. The fit was not great, the exhaust rattles sometimes because it is hitting one of the braces under the car and the tips are not even out the back.
Old Dec 17, 2008 | 01:07 PM
Billy@EnglishRacing's Avatar
Give them a call, Michael will take care of you
360-263-3748
Old Dec 17, 2008 | 02:36 PM
Jooyoung99's Avatar
I had ETS for a while. I really loved the sound. It's very aggressive. But it's pretty loud with a test pipe. So if you're planning to get a test pipe, make sure you like loud exhaust sound.
In terms of quality and build, it's one of the best.
Old Dec 17, 2008 | 02:40 PM
JDW1479's Avatar
I was planning on getting a test pipe, so thanks for the test pipe advice. Looks like I will be looking some more. But man, I really like the sound of the car idling.
Old Dec 17, 2008 | 02:48 PM
yeah you just have to lower it a little bit, that the only think i dont like about the exhaust is how low the tips are.
Old Dec 17, 2008 | 03:10 PM
Skyline559's Avatar
http://www.youtube.com/watch?v=ZevNbEWPDh4 sound really nice man
evo_x mr
Aug 13, 2016 06:22 PM
Shaun@AWDMotorsports
EvoX 'For Sale' External Engine / Power
143
Jun 14, 2016 10:27 AM
90GSXDan
ExtremeTurboSystems.com – WA
Sep 24, 2008 10:37 AM
Spazpilot
25
Aug 27, 2008 07:24 AM
ETS Michael
30
Nov 14, 2007 01:46 PM
