Tsb 08-13-011
They wouldn't flash mine because it wasn't pulling the number, even though my car qualifies. They also went on to say my syncro's which crunch terribly loud and shifts rough was said to be a characteristic of the car, Marhofer is not the place to an EVO, nor was medina!
I bought my lancer de a few months ago and am not sure if the tsb on brakes for the de's affects my car or if they already fixed it. How do I find out? Where are they suppose to put the sticker?
I've been looking for the actual TSB to print out and examine.
I want to know what ECU ROM revision should be reported by the ECU if this flash has been applied.
I just purchased my MR about a month ago, so I assume this has probably been done already.
That being said, I'm not going to trust that assumption.
yep, South Coast Mitsu put a sticker under my hood last month. However, the tach needle still jumps as of today...
had my car reflashed by the dealer car ran fine now its throwing P0171::system too lean(bank 1).....thought it was my intake but nope same freaking issue, and the idle problem has gotten worse....any fixed to cure this? Maybe take it back to the dealer and get it reflashed again?
therocket
May 6, 2009 03:23 AM
