Sponsored by:
Sponsored by: CARiD
FAST Key not so....fast?
Old Apr 29, 2009 | 03:41 PM
unowned's Avatar
Originally Posted by Jedi_Gill
The design of the system is to prevent the car to unlock when you go to the trunk after locking the door and vice versa. Imagine you get out of your car.. lock it.. pop the trunk and the car unlocks because you get too close to it..
talk about misinformed ... the door only unlocks when the inside of the door handle detects heat not when you are nearby
Old Apr 29, 2009 | 03:55 PM
UT_Evo's Avatar
Wait, what? For real? Mitsu did what to the fastkey system? I no longer think it is that cool that the Xs have fastkey. All the other "fastkey" type systems I've been around have nothing to do with detecting heat (that would suck! what if I was wearing gloves, or it was freezing cold outside!). The mini-s I just drove a few days ago just had a little teenie button on the handle you pushed and it unlocked. Only needed one finger to do that. There's really not some little button or some other lever? It is controled by heat?
Old Apr 29, 2009 | 04:13 PM
EndlessRed's Avatar
lol aw come on dude read the manual! it tells you specifically it's activated by the strip that's behind the front door's handle!
but is it heat sensitive? i thought it was touch sensitive. guess i'll go bust out my manual too.
Old Apr 29, 2009 | 04:16 PM
Preludepearl417's Avatar
Wow weird ive been having the same problems but just thought it was MY car....
Old Apr 29, 2009 | 04:17 PM
sith_killer_99's Avatar
Wow, RTFM!
F.A.S.T. = Free-hand Advanced Security Transmitter
The key uses weak electromagnetic waves to communicate with sensors. Operating range is approx. 2.3 feet.
Time settings (delays before unlocking) may be adjusted by Mitsubishi.
OP the delay you are experiencing is from moving out of range of the trunk sensor and into range of the door handle sensor. If you want quicker reaction time talk to a Mitsu dealer, they should be able to adjust it for you.
I read nothing in the manual about heat sensing.Just what was mentioned, a simple touch sens. strip.
On a side note, I highly recommend people with F.A.S.T. keys read their manual, I would hate to hear someone got locked out of their car because the battery went low in their key or electromagnetic interference was messing with their sensor and they had to get a tow! lol
Old Apr 29, 2009 | 04:24 PM
UT_Evo's Avatar
I thought it sounded crazy too! I don't have a manual to read, and my car isn't cool enough to even have the option of coming with fastkey type system
Originally Posted by sith_killer_99
I read nothing in the manual about heat sensing.Just what was mentioned, a simple strip.
Good, I'm glad you cleared that up for me, I was a bit freaked out. Mitsu has done some weird things (Endeavor TC in the '03 Evos, for example) but come on. And yeah, always read the manuals for the high tech gadgets, though... If it's anything like the section on the DCCD for the new STi's it won't help much Instead of saying what it actually does, it just tells you what it is for "Switch to plus mode in case of inclimate weather, switch to minus for a more precise steering feel" man, can't you just say "plus puts more power to the front, and minus puts more to the rear"? Anyone buying an STi can figure that out.
Old Apr 29, 2009 | 05:23 PM
aftershock141's Avatar
The fast key in my trunk won't work no matter what. To get the front doors to work, I have to pull once. It then beeps. After that, its golden.
Old Apr 29, 2009 | 05:51 PM
EndlessRed's Avatar
you sure it's not just a battery problem with your fast key? also, you have to hold the handle and pause. you don't have to pull it in order for it to recognize your key.
Old Apr 29, 2009 | 07:31 PM
unowned's Avatar
the door will not unlock if you are wearing thick gloves for example i was wearing my mechanix gloves.
Old Apr 29, 2009 | 08:12 PM
Funny, I just double checked.
1. Placed small towel around door handle.
2. Locked door.
3. Stepped back.
4. Walked back towards door with FAST key in my front jeans pocket.
5. Pulled on towel without putting hand or fingers around back side of handle.
6. Opened door with no problems, pulling on towel only.
lol
Old Apr 29, 2009 | 09:35 PM
chopstixx's Avatar
okay dudes everyone should kno why it does the trunk to door thing
its cuz u need to take those 3-5 seconds and just admire your damn car
it wants you to notice the sexy curves
Old Apr 29, 2009 | 09:52 PM
onyx1121's Avatar
Okay, so it has a 3 or 5 second delay - I think we have established that, but I appreciate the creative responses and suggestions. Yes, I can work around this, but it seems dumb.
I'll try asking the dealer if they can attempt to set the delay to zero, or something at least lower than 3. I don't have Navi., so I don't think I can do it (I could check the manual....but I have some other stuff to do).
Nonetheless, its annoying and I'm not sure what the designers were thinking.
FYI - in the car's manual, 3-21, second column, bullet #3. Says dealer can adjust it, we will see when I go in for my oil change.
Old Apr 29, 2009 | 10:36 PM
heel2toe's Avatar
This is why the fast key also has a real key included with it just incase.
Old Apr 29, 2009 | 10:38 PM
higgs's Avatar
seems like mine works money when i put my hand over door handle and just kind of pause.... i always have my iphone bluetooth on with me and as long as i'm not going back to it within like 20 secs right after i lock it or vice versa its fine (ralliart 09, assuming same system)
Old Apr 29, 2009 | 11:12 PM
evazerone's Avatar
Yup, it works fine for me as long as I pause a second before opening the door. Also, when the key is in my pocket, it works better when I have my waist closer to the door. If I reach out my arm with my butt away from the door (I don't know why I would do this but I do have longish arms), it doesn't always sense the key.
