Sponsored by:
Sponsored by: CARiD
fans stayed running after car was off
Old Jul 9, 2009 | 05:13 PM
sonicrx's Avatar
i drove home from work today about 45 minutes. got home shut the car off for 10 minutes then got back in it started it ,and drove 30 secs shut it off and the fans were going. ignition was all the way off i double checked. went in 2 minutes came back out fans still going .got in the car started it up fans still going drove 100 yards and they shut off.. i could not duplicate this again... has anyone had this happen ? any ideas or thought? i thought it could have been the car got hot but i checked the little gauge in the middle and it looked fine,and i would think key off,fans off.. it seems fine now anyways
Old Jul 9, 2009 | 05:26 PM
EvoX_SA's Avatar
it is the car. It is built in from the factory, kind of like turbo timer. When the car is hot the fan stays on for a few miniutes to cool the car off
Old Jul 9, 2009 | 05:27 PM
UFO's Avatar
UFO
Read the manual: it's a feature. It's like your very own turbo timer. Certain conditions have to be met, but the fans will carry on running for a set period of time. If I drive home and fill up with gas round the corner, then drive the 2 minutes to my house the fans always run.
So, basically, this has been covered a bunch of times before and it's normal behaviour.
Old Jul 9, 2009 | 06:02 PM
scottatyamaha's Avatar
Had my car for almost two years and my car has never done this.
Old Jul 9, 2009 | 06:18 PM
Laz's Avatar
Laz
Mine has did this 4 times now and I bought it in May. Glad to know it's normal.
Old Jul 9, 2009 | 06:57 PM
CatalystGod's Avatar
Absolutely normal in many modern day cars.
Old Jul 9, 2009 | 07:01 PM
SR20gawd's Avatar
Registered User
Yes very normal.. however I wish they also had an afterun (aux) coolant pump also. Audi/VW uses this on their vehicles. This allows the cooling to be even more efficient after you've shut the car off.
Old Jul 9, 2009 | 07:12 PM
Hiboost's Avatar
This probably occurs in warmer climates more often, but last summer it happened a few weeks after I bought the car. From the factory they usually fill the car with a 60% coolant to 40% water mix which is good for -65 F temperatures but not as good for heat transfer. I Drained the coolant and used my density gauge to measure where I was at and added distilled water to change it to 40% coolant / 60% water mix (-12 F) and added a bottle of Redline Water Wetter.
Ever since then my car has never ever kept the fan on after shutting down the engine, even after 30 min of hot laps at Watkins Glen. Basically the efficiency of the cooling system keeps it from heat soaking as much and your thermostat lets you get to the warmup 175-190F zone and keep it there. Right after you park it I'm sure it still jumps up a bit since there is no flow but it doesn't creep to the 215-220F area where the panic fan kicks in with the car off.
Old Jul 9, 2009 | 07:16 PM
compscibOi's Avatar
Rtfm!!!!!!!
Old Jul 9, 2009 | 08:52 PM
xi's Avatar
xi
Well its not really a true turbo timer, it doesn't keep the motor running and circulating oil. So after boosting, you'd probably have to keep the car running for a minute or two before shutting it down so the oil doesn't cook inside the turbo.
Old Jul 9, 2009 | 09:05 PM
evosoh's Avatar
As the turbo is now so near the firewall, the fan comes on after the engine is turned off to assist in keeping temps down.
Old Jul 10, 2009 | 02:28 AM
Project_Evo's Avatar
Mine has done this recently for the first time. After about 4 months of owning.
Old Jul 10, 2009 | 01:07 PM
MR.Wicked's Avatar
if you read the sticky regarding the bulletin for servicing the EVO X you will see all the things like this that people wonder about. Will save alot of face if we all read it.
Old Jul 10, 2009 | 01:13 PM
atombomb33's Avatar
EvoM Community Team
Really? And you're in SC. Would have figured it would have triggered the fans on your car especially in the heat you guys get. It's happened on my car a handful of times up in NC.
To the OP, it's normal
Old Jul 10, 2009 | 04:34 PM
Webman's Avatar
RTFM, seriously. It's in there.
