Sponsored by:
Sponsored by: CARiD
1st to 2nd on wot
Old Aug 10, 2009 | 12:24 PM
Xtremist's Avatar
Yeah that's the issue, the rpm's drop way too fast in the car. I do believe it's due to the small turbo loosing spool in between gears. I sometime still have issues but have gotten better with it. All manuals will do this though!
Old Aug 11, 2009 | 09:09 AM
initialdrew's Avatar
it has to do with the way you shift,
AWD + granny shifting + lauching = FAIL
the faster the shift, the more accurate and gentle the clutch release is the better.
Old Aug 11, 2009 | 11:13 AM
Xtremist's Avatar
No one's trying to granny shift here, it's called taking care of what you got! The rpm's drop twice as fast as a normal car due to it's set up! I've shifted fast and smooth and still receive the shock at times! This never happens in my Dad's truck, it's simply going to happen from time to time in an AWD/Turbo charged car! I don't care how good you guys "think you are" at driving, it's going to happen from time to time. It all comes down to rev matching your shifts, releasing the clutch smoothly and applying the proper amount of gas after the shifts complete! The drive shaft is also made of light weight materials which is more prone to shift shock.
P.S. It's rather hard to pop the clutch when your behind traffic and need to shift. Each situation is different, the higher the rpm the faster you can release, the lower the rpm the slower you release.
Old Aug 12, 2009 | 07:27 PM
yblegal's Avatar
Originally Posted by ct63084
Hey guys this is my first manual car, so sorry for the noob post. So i tried taking off on the evo and i was just wondering the gear change from 1st to 2nd on wot feels like the engine is going to lunge out of the engine bay, it's kinda violent. IDK if that's normal or i'm doing something wrong, every shift from 3rd to 5th are not as violent. Pls advice?
PS. I'm not powershifting.
Maybe think about a tune designed by a tuner to assist your driving skills. I had my son flash in a No Lift Shift (NLS) that really helped me smooth out my shifts. I also included a valet mode and a stage rpm the helped me shift better.
shane_evo7
Nov 11, 2016 09:23 AM
Gsxtremedsm
Oct 28, 2012 03:47 PM
Broham
Dec 23, 2009 04:28 PM
gizmotoy
Jan 23, 2009 09:10 PM
raytrix
Driving Techniques
15
Oct 13, 2008 05:20 AM
