Sponsored by:
Sponsored by: CARiD
AEM meth kit problem?
Old Aug 28, 2009 | 09:07 AM
proracer718's Avatar
Installed a AEM meth kit into a Evo X, as per the instructions all wires are connected correctly, double and triple checked.
The problem is I have an error light, light blinks once and about 1-2 seconds later blinks once and it continues to do that.
Just in case wires were cut or anything new wires were ran from the pump in the trunk directly into the car to the controller. When test button is pressed the meth shoots but not steady only in pulses. So the brown and white wires were ran direct from pump to controller and still same problem. connected brown and white wire together at controller and still the same problem. Ran the orange wire direct, still no help.
Has anyone have a problem like this? or is there anything else I can check? Also what is the unit telling me the error is with the one light that blinks about every 2 seconds????
All help is greatly appreciated.
Old Aug 28, 2009 | 11:48 AM
tenevoten's Avatar
sounds complicated Did you tune it after the install it?
Old Aug 28, 2009 | 12:26 PM
Install was made and when car was going to be tuned and kit was going to be set, it did not work only only blinked with the error light.
Old Aug 28, 2009 | 12:31 PM
BlueX83's Avatar
umm no meth for me! should go E85
Old Aug 28, 2009 | 01:25 PM
rogue's Avatar
You should call AEM, they have an excellent help line.
Old Aug 28, 2009 | 02:31 PM
Yep, called them, they are saying I would need to mail them the controller back which seems to be defective.
Old Aug 28, 2009 | 02:36 PM
Old Aug 28, 2009 | 05:24 PM
Jabjab's Avatar
something with the current in the controller aem replaced a friend of mines that was having this issue as well
I have had my aem kit for about 1 month so far no worries yet, got it tuned by AMS. I love the kit
mrwickd123
Evo X How Tos / Installations
30
Feb 20, 2019 09:29 PM
suprPHREAK
Toronto Lancer Club
62
Dec 15, 2016 10:17 AM
avo3vom
Aug 12, 2007 08:56 PM
DRFTKNGG
Jan 12, 2007 07:12 AM
nrgaura
Lancer Troubleshooting
Oct 21, 2004 05:28 PM
