Sponsored by:
Sponsored by: CARiD
Attention All X Owners.... Do this ASAP....
Old Sep 2, 2009 | 11:39 AM
J5isalive2's Avatar
(I'm not taking credit for this picture....)
There is a hose from the Fuel Pressure regulator to the intake manifold. Mitsu did not put any type of clamp on this hose. It will pop off and cause you to run lean, and ruin your idle. It is a simple vacuum line, but is difficult to see when trying to diagnose a problem...
The hose is located near the dip stick. All you need is a couple zip ties....
Heres a pic.
There are one 2 many "My idle is shaky" thread on the opening page..... this is likely everyones problem....
Old Sep 2, 2009 | 11:46 AM
ToddMcF2002's Avatar
This should go in the known issues sticky. I wont take credit for that idea or the picture or the discovery.
Old Sep 2, 2009 | 11:48 AM
J5isalive2's Avatar
I was happy to find this picture in another thread LOL, kept me from breaking out my digi cam
Old Sep 2, 2009 | 11:55 AM
El_Kameleon_G's Avatar
It should cause it to run rich. It's the FPR hose.
Old Sep 2, 2009 | 12:02 PM
GiLizILL's Avatar
hmm I wonder if this applies to Ralliarts too?
Old Sep 2, 2009 | 12:52 PM
mike100's Avatar
The boost levels on the RA probably won't be high enough to pop it off as easily as the evo.
Old Sep 2, 2009 | 12:56 PM
gotrnet's Avatar
had this happen about two weeks ago. the car idled like crap from the vacuum leak and since it ran to the FPR the pressure wasn't raising with boost so it ran really lean, like 16 to 17:1. luckily i took a min and took the engine cover off and saw it immediately.
Old Sep 2, 2009 | 01:00 PM
Olaboy808's Avatar
Thanks for the pic!
Old Sep 2, 2009 | 01:04 PM
08EVOVA's Avatar
I had the same issue last week
Old Sep 2, 2009 | 01:28 PM
J5isalive2's Avatar
it isn't a question of if it will happen.....it is when it will happen..... prevent this before it happens to your car.
You really end up feeling like an ******* sitting next to someone at a red light and your car is stumbling all over itself... especially when your exhaust is loud as hell and makes sure everyone in the immediate area can here your car almost dieing LOL.
Old Sep 2, 2009 | 01:38 PM
Liuspeed's Avatar
thanks
Old Sep 2, 2009 | 02:32 PM
supergengo's Avatar
Noob question:
If it's a vacuum line, what is causing it to pop off? I would understand if it was under pressure...
Old Sep 2, 2009 | 02:45 PM
evolvedx's Avatar
It's not exactly a vacuum line - it's tapped into the intake manifold so it see's intake pressure under boost.
Old Sep 2, 2009 | 02:55 PM
pcasso87's Avatar
did that and mi idle is still going crazy, i hope the tune takes care of it
Old Sep 2, 2009 | 02:57 PM
cweav's Avatar
I had this happen last week as well, took me forever to figure it out... thanks for posting this picture
