Sponsored by:
Sponsored by: CARiD
Moisture in Fog Lamp??
Old Nov 26, 2009 | 01:20 PM
wicked white14's Avatar
Is anyone having issues with moisture in the fog lamp?? I had actual sitting water in the drivers side?? Pulled the unit out, dried it, but do not want to deal with this. Anyone have any ideas how water got in there??
Old Nov 26, 2009 | 06:38 PM
Shea561's Avatar
Sounds like just basic condensation build-up. Not suppose to happen but it does...on alot of cars. There might be a fine crack where water is seeping through. Only way is to get a quick drill and small bit and put a hole on the bottom so the water drains out. You can do that or try and fix or repair where the area where the water is coming in. Last resort, just buy a new one. Good luck.
Old Nov 26, 2009 | 06:42 PM
buchnerj's Avatar
Look for the crack and seal it up with some silicone. Once you do that take it inside overnight and let the headlamp dry out and the silicone dry really well. It shouldn't happen again.
Old Nov 26, 2009 | 08:04 PM
blueberryyumyum's Avatar
i have the same problem as well.. i think its pretty common issue with any foglamps.. Ive had the same issue in my rsx-s. ive given up and have already accepted the fact that it concendation will always build up in there. but if theres a good amount of water actually in the lamp then i would take it into the dealer for a warranty.
Old Nov 26, 2009 | 08:57 PM
Optiblue's Avatar
I had this problem as well when I had a smarteye HID kit... it was horrible! Thought it was the seals, so ended up getting a DDMtuning hid kit and blew dry the foglamps... so far so good (keeping fingers crossed)! If you're getting condensation with stock halogens, I think it's just a common problem with all of our cars
Old Nov 26, 2009 | 09:07 PM
buchnerj's Avatar
Yeah, I wouldn't let it sit in there for too long. If it contacted the bulb and housing, never know what a short could do to the electrical system...
Old Nov 27, 2009 | 04:04 AM
Bighec's Avatar
I have a solution!!! Evo X RS fog light delete kit from Japan Parts -dot- com!!!
Old Nov 27, 2009 | 09:05 AM
Thanks guys, I think after the winter it is time for a fog delete kit for sure!!!
Pipefish
Outlander Sport
28
Jul 21, 2025 03:57 AM
mjp10mlrsb
Mar 3, 2015 03:04 PM
gotrnet
Jan 28, 2011 06:24 AM
Yarima
11
Aug 7, 2009 06:25 AM
dgrumpys
Jun 10, 2009 03:56 PM
