Sponsored by:
Sponsored by: CARiD
View Poll Results: Which BOOST CONTROLLER
Turbosmart e-Boost2
2.33%
HKS EVC
14
32.56%
Other
28
65.12%
Voters: 43. You may not vote on this poll
Which Boost Controller?
Old May 23, 2010 | 05:50 PM
monkey_187's Avatar
I had the EVC VI and was very happy with it, was pricey but worth every penny.
Old May 23, 2010 | 06:02 PM
Robevo RS's Avatar
i think if you dont want to run other then pump gas , then the factory set up is the best.
So i think its a waste of money in that situation.
If you need a higher boost because you run different turbo or race gas etc, then the MBC with a boost gauge is the best. /i prefer halmann pro RX/
The X has a better oem boost controlling system the the previous evos. Just need a new wastegate actuator.
Old May 23, 2010 | 09:13 PM
aftershock141's Avatar
Removed.
Old May 23, 2010 | 09:15 PM
stokEd's Avatar
Originally Posted by JFuego777
Not sure about the way this would work on an X, but I went with a GM 3 port solenoid and self tuned with ECUFlash, install took about 30 minutes, tuning maybe 2 hours total. The reason I like it is you have absolute control over how much boost at what RPM.
Another vote here for the GM 3-port (PnP harnesses now available!) and tune.
The stock ECU can control boost very well, no need for a standalone boost controller, just extra spent $$$.
Old May 24, 2010 | 05:31 AM
TJs98GT's Avatar
very good info in this thread. seems like the GM is the obvious winner here.
Old May 24, 2010 | 12:02 PM
MR. Tim's Avatar
Where is the PnP harness available at?
Old May 24, 2010 | 12:28 PM
JustJeff's Avatar
Yeah I would suggest GM 3-port. Sounds like the best option.
Old May 24, 2010 | 12:47 PM
stokEd's Avatar
SpoolinUp.com sells them or you can make your own.
Old Jun 6, 2010 | 10:06 AM
advancEvo27's Avatar
nvm
MrFreddieA
Jun 9, 2015 07:54 PM
blade3609
Jul 30, 2011 08:20 PM
mitsuevodriver
Sep 17, 2009 12:54 PM
TKEVO
24
Aug 16, 2007 06:02 AM
dktop
10
Sep 9, 2004 06:10 PM
