Fuel pump relay?? TSB?
Old Jan 15, 2010, 11:49 AM
jrsimon27's Avatar
was there a tsb for the fuel pump relay? i ask cause i called my dealer and they say they dont know nothing on it,also i asked for the a new relay for the fuel pump and they came with part number#mr588567 i told them that other dealers are changing them to part number #8627A011 but they told me what the had in stock was the first one and i told them thats the one my car has right know so they are asking where is a tsb for this?
thanks for the input i searched but didnt come up with a tsb.
Old Jan 15, 2010, 02:37 PM
ikt
ikt's Avatar
i hadnt seen an official one, but i did the swap as well. I think the headlight relay might actually be the same part number
Old Jan 15, 2010, 03:32 PM
jrsimon27's Avatar
but if you go to mitsu and ask them for the fuel pump relay they give you the same black one not the green one why?
Old Jan 15, 2010, 03:44 PM
KPerez's Avatar
There is a TSB for this relay although I cannot find it at this moment other than to say I went in to dealership to just pay outright for the "green" relay (~$38) and they told me that there is a TSB for "idle problems" and replaced the relay on warranty. The replacement is exactly the same one as that for the headlights; for some reason, Mitsu used a different relay for the fuel pump from the factory but are now replacing same with the "green" relay.
As a side note, when I went in today for some installs, I was told Mitsu asked to have my OEM "black" relay, removed earlier as per above, returned to them directly for testing. Why is Mitsu so interested in this relay if it is just for a problem with idling?
The failure of this relay has been suggested as a possible cause for engine failures due to lean conditions on modified and relatively stock X's (see https://www.evolutionm.net/forums/ev...misfiring.html).
Later, Ken
Old Jan 15, 2010, 08:33 PM
jrsimon27's Avatar
ok so when i go to the dealer i just ask them for the green relay cause they wanna sell me another black one uurggg they dont get it
Old Jan 15, 2010, 10:28 PM
Brokenevo's Avatar
Im going to be asking about this as well! thanks
Old Jan 15, 2010, 10:58 PM
mump's Avatar
I just picked up the #8627A011 green relay a couple days ago. On the package, it is marked #8627A011 "Horn Relay" - It cost me around $18.
Old Jan 16, 2010, 03:31 PM
wicked white14's Avatar
Totally stupid question, but........Is the relay just a plug that you pull out the old with your fingers and just place in the new one?
Old Jan 16, 2010, 03:40 PM
MicMcKee's Avatar
Correct
Old Jan 16, 2010, 04:51 PM
jrsimon27's Avatar
ok guys know iam confused i go to another mitsu dealer and ask for the green relay and they tell me my car allready has it i took pics so you can help tell me which one it is cause they say the black one is for DRL
they told me to use as reference the fuse box cover take a look
Old Jan 16, 2010, 04:55 PM
jrsimon27's Avatar
they are telling me this is the fuel pump relay???
Old Jan 16, 2010, 04:58 PM
jrsimon27's Avatar
this is it was gives them reference to the relay as you can clearly see the left relay black one is for the DRL so are they correct?
Old Jan 16, 2010, 04:59 PM
jrsimon27's Avatar
sorry cant use paint jajajaj
Old Jan 16, 2010, 07:58 PM
jrsimon27's Avatar
could someone with a 2010 check the relay to see if mitsu changed them-?
also if the 2010 have the same black relay does the car have like check engine light or a warning if it goes to lean?
Old Mar 22, 2010, 05:56 PM
love9sick's Avatar
I thought the black on on that picture is the fuel pump relay left of the most top green one.
Quick Reply: Fuel pump relay?? TSB?
