Sponsored by:
Sponsored by: CARiD
Does the X's battery just suck or what?
Old Jan 17, 2010 | 06:46 PM
Methodical4u's Avatar
It just doesn't seem to turn to starter over very quick... especially when it's cold. I know this may be normal to the Evo, but is it because the battery sucks? If so... which is a better one to get that doesn't do this?
Old Jan 17, 2010 | 07:55 PM
lousEVOxmr's Avatar
, befor starting ,
turn your key so the fuel pump is on, youll hear it ,
take the time 4 to 5 sec or the time it takes to put a seat belt on and then start it ....
i had 3 mistu and all did the same thing
Old Jan 17, 2010 | 08:17 PM
wiretap's Avatar
I've started my X on many days where it was around 15F degrees out. Of course it's going to be a little bit slow, that's expected, but I never had a problem. It helps to keep your car's front end facing away from any wind on cold days like that. If possible, park it in the garage. If you don't have a garage, build one.. Mitsu's paint sucks enough as it is and building a garage is cheaper than getting a new good paint job later on down the road.
Old Jan 18, 2010 | 10:47 AM
Originally Posted by lousEVOxmr
, befor starting ,
i'll try that, but I may wind up getting a better grounding kit.. I read it saves gas, starts better, helps everything that has to do with the electric system.
Old Jan 18, 2010 | 11:02 AM
mlomker's Avatar
Do you have the Optima? I've never had a problem and it's been colder than heck here.
Old Jan 18, 2010 | 12:00 PM
atombomb33's Avatar
EvoM Community Team
I've got the stock battery and agree that it sucks. Oddly enough, it just died on me in my driveway. I could tell it was gonna go. It has been starting extremely slow lately. And, it finally died. I'm on hold with Mitsu roadside assistance to get a jump Then off to the dealership to try to get the stock battery replaced with an Optima Redtop (which is something Mitsu dealers were doing when the car first came out).
Old Jan 18, 2010 | 12:25 PM
Golden's Avatar
FYI, you can park directly into the wind and it won't matter. Once the engine reaches air temp, it cannot get any colder. The wind will just help it get there faster.
Wind chill is just a number to show how cold out it feels to a human with a body temp of 98.6*.
Old Jan 18, 2010 | 03:30 PM
atombomb33's Avatar
EvoM Community Team
Just a quick follow-up. The people on the phone from Mitsu roadside assistance were helpful and nice. They actually had someone arrive within 30 minutes of when I picked up the phone to call them. Nice to see them come through
Old Jan 20, 2010 | 01:51 AM
Brokenevo's Avatar
never ever had a prob!
Old Jan 20, 2010 | 05:24 AM
motox502's Avatar
Its a tiny battery, I wouldnt give it too much credit
Old Jan 20, 2010 | 06:47 AM
Hiboost's Avatar
I swapped with an STM 14 pounder, so far it's been ok this winter but I have the original battery charged up ready to go with a booster charge every couple months just in case. The stocker definitely has more size for reserve power but the cranking speed seems to be very similar unless you are in sub 10* F temps.
Old Jan 20, 2010 | 07:09 AM
scarryy's Avatar
Mine has always started even at 15 below. Yes it cranked a little slow, but fired up no problem
Old Jan 20, 2010 | 03:59 PM
Metatron723's Avatar
The dealer replaced mine with a Optima Red Top under warranty! The factory battery sucked.
Old Jan 20, 2010 | 05:31 PM
Clark_Kent's Avatar
I've never had a problem with mine.
Old Jan 21, 2010 | 06:59 AM
EVO LVED's Avatar
The factory battery only has around 360 cold crancking amps. I just charged mine, and it still gives problems on cold mornings. You can upgrade to one with 750 cca.
