Sponsored by:
Sponsored by: CARiD
wideband bung on custom HFC
Old Feb 17, 2010 | 06:35 PM
vivac2's Avatar
Hi!
I would like to know where to put the wideband bung on my custom HFC.
between the downpipe and the cat....on the cat.....after the cat?
and what about the o2 sensor....where do I put it?
thanks!
Old Feb 17, 2010 | 06:56 PM
RaysEvoX's Avatar
wideband goes before the cat and there should be a O2 sensor before and after the cat.
Old Feb 17, 2010 | 08:34 PM
vivac2's Avatar
so, according to your post RaysEvoX, on, for example, the AMS HFC...there are 3 bungs?!?!?! 2 for the o2 sensors (1 before and 1 after the cat) and 1 for the wideband?!?!?!
How come on all the aftermarket HFC there are only 2bungs including the one for wideband.....
Old Feb 18, 2010 | 06:20 AM
EVOXMAINE's Avatar
There are 2 bungs for The factory O2 sensors. If that is the case you must get a third welded on, or shut the rear O2 off via AP and put it there if you have a test pipe. This can't be done with HFC because it would be after the cat.
Old Feb 18, 2010 | 06:55 AM
vivac2's Avatar
anyways...the primary o2 sensor is on the dowpipe. So, if I go custom...I only need to add one wideband bung before the cat and one bung for the factory 02 sensor after the cat.
Old Feb 18, 2010 | 10:30 AM
LaXGSR's Avatar
Yes that is correct. Primary o2 (stock) is on the downpipe. On the test pipe or HFC, you will need to have one bung before the cat for your wideband, and one bung after the cat for your factory rear o2.
Old Feb 18, 2010 | 12:26 PM
vivac2's Avatar
Great!! thanks!!!
ToddMcF2002
Jan 29, 2011 06:54 PM
RedEvoxGSR
Jun 15, 2010 10:47 PM
japan101
Feb 12, 2010 05:54 PM
LakerRaider
Jan 17, 2009 11:18 AM
orikosan
11
Jun 21, 2004 11:05 PM
