Sponsored by:
Sponsored by: CARiD
Day time Driving lights
Old Mar 15, 2010 | 11:31 AM
bigzz's Avatar
Hi all, i have searched and searched but cant seem to find the answer to my problem. For some reason my driverside day time driving light keeps burning out. i have replace the bulb numerous times and they only last for an hour or two max. i have checked the fuses. Any ideas?
Thanks
BigZZ
Old Mar 15, 2010 | 03:04 PM
slo4g63's Avatar
Just basic stuff that you probably already know but you aren't letting the bulbs touch anything when installing are you? Including and especially your fingers? And, is it sealed off good when installed?
Old Mar 15, 2010 | 07:41 PM
Ikon's Avatar
^^^ditto..
Old Mar 16, 2010 | 12:18 AM
sbkimm's Avatar
i just installed led bulbs today, i will have to keep an eye on them. what are you replacing them with?
Old Mar 16, 2010 | 06:25 AM
Cpt. Picard's Avatar
Where did you get the LED bulbs at? My day time driving lights are burning out constantly that now I just leave the dead bulbs in there. I even made sure to use surgical gloves when installing them.
Old Apr 13, 2010 | 02:57 PM
bigzz's Avatar
Update: so i figured out what was happening in my case, the terminal were the bulb was making contact had a light layer of corrosion. cleaned it up and yup all my "bad" bulbs seemed to work again. i also adjusted the springs in each of the day time driving bulb sockets so that they put more pressure on the bulbs when installed.
Old Apr 13, 2010 | 07:09 PM
Golden's Avatar
You could also pull the fuse for the day time running lights (fuse 13 iirc) (HID cars only) and not have to worry about it at all.
Old Apr 13, 2010 | 10:22 PM
TruSlide's Avatar
^best mod ever
Old Apr 14, 2010 | 12:09 AM
jRox's Avatar
For those without the HID package, there's a Plug & Play solution to eliminate the DRL's.
Old Apr 15, 2010 | 08:41 PM
JebusMKIV's Avatar
Is there a how to on disabling SSS DRLS?
Old Apr 15, 2010 | 08:49 PM
wiretap's Avatar
Pull the fuse for them under the hood..
Old Apr 15, 2010 | 08:56 PM
JebusMKIV's Avatar
Sweet, thanks!
BTW, does this cause a bulb out warning? Do Evo X's have that?
Old Apr 16, 2010 | 04:12 AM
bryanlo's Avatar
if the car was under warranty will mitsubishi cover something like this?
Old Apr 16, 2010 | 04:54 AM
JaCe's Avatar
Silly question from an Aussie but where are the daytime running lights on your Evo X's?
Old Apr 16, 2010 | 07:43 AM
slo4g63's Avatar
If you mean which bulb, its the outer bulb (same as headlight) on non-SSS packacge (no HID) and the inner bulb if you do have SSS (or HID) package. DRL on HID equipped is a seperate bulb from DRL's.
Remove fuse #13 under the hood for the SSS DRL's disabling.
