Sponsored by:
Sponsored by: CARiD
How to go from 23mpg Highway to 29mpg
Old Apr 5, 2010 | 12:14 PM
  #136
murlo26's Avatar
Originally Posted by tsitalon1
You can log the LTFT's yourself using Evoscan and openport 2.0. If the LTFT is more than 5% off you need to make adjustments or you could have an exhaust leak preventing the 02 sensor from accurately measuring the A:F ratio...Check for exhaust leaks....should see black soot where there is a leak.
The fact that this started when the CB was installed, tell me, you very well could have a leak...
Since it is just a catback an exhaust leak from that would not affect his AFR's at all, since the sensor's are pre-catback.
I doubt that is the problem.
Regardless, you should be able to lean you car out a bit more, even if it is 11.0/1 and not 10.1, you should be able to get away with 11.5.
Old Apr 5, 2010 | 12:20 PM
  #137
Spoonie's Avatar
Thanks Guys!! I'm looking into purchasing a Tactrix Cable. I might also bring it back to the person who tuned it. Seems like my fuel trims are off. and he didn't rescale the MAF. He also didn't seem to adjust the injectors. I'm pissed.
Old Apr 5, 2010 | 12:42 PM
  #138
tsitalon1's Avatar
I would not bring it back to that guy ever again...All that should have been done by him in the first place. I would seriously doubt his competency....
Good luck man, do us a favor and post your findings and MPG after the fix
Old Apr 5, 2010 | 12:44 PM
  #139
tsitalon1's Avatar
Yeah, I thought of that, just wasn't sure what was done during the install (maybe yanked the o2 sensor cable) or maybe spoonie forgot to mention a TP...was just throwing it out there...
At any rate, Spoonie's latest post seems to point to the problem.
Old Apr 5, 2010 | 01:53 PM
  #140
Spoonie's Avatar
I will. But it will be about 3 weeks before I get a tactrix cable.
Old Apr 5, 2010 | 08:24 PM
  #141
BlackZero's Avatar
I've been averaging 280-300 miles per tank.
Old Apr 6, 2010 | 03:23 PM
  #142
Methodical4u's Avatar
wow, you must be another one of those crazy people that imagine their mileage like me!
Old Apr 6, 2010 | 03:42 PM
  #143
St1g's Avatar
trip from los angeles -> san diego, my average = ~24.5mpg. evo x mr with aero package. cruise control the whole way @ 72mph.
i have intake / exhaust mods. no tune.
275 width tires, dunlop z1's, @ 35psi cold. -2.4deg front camber, -1.4deg rear.
i would imagine with stock width tires and a tune, the consumption rate would be significantly better. > 26mpg is not hard to imagine.
as a mr with the aero package, it has that huge wing and all the appendages. remove the aero and wing, maybe even 27mpg.
reduce cruise control to 60-65mpg, might add 1-2mpg more, keeping boost at a minimum. 29mpg might actually be possible.
Old Apr 7, 2010 | 07:22 PM
  #144
off topic for a second, but you really should get a tune with your mods when you can afford it.. it might not be to great for your engine... but i'm no expert.
Old Apr 7, 2010 | 07:26 PM
  #145
Filled my tank up today. 12.488 gallons, 281.9 miles... it wasn't on the last bar before it shows completely empty, the Evo's tank is also rated at 14.5 gallons, although I don't see how that is possible. I filled it up the same way I always do which is almost letting it spill over... that's 22.57 mpg AVERAGE. at least 35-40% of my driving is around town errands, grocery store, etc.
Old Apr 7, 2010 | 07:49 PM
  #146
ODUB's Avatar
get your car tuned. you can get better gas mileage that wway. how much better I don't know, but these things run rich from the factory.
Old Apr 8, 2010 | 10:48 AM
  #147
St1g's Avatar
agreed. reason i haven't is because my rom was not mapped until recently. before i left on a business trip they were working on the data logging. they might be ready now, but i haven't had the time... soon!
Old Apr 8, 2010 | 02:47 PM
  #148
nemsin's Avatar
Buy a Prius?
Old Apr 8, 2010 | 07:16 PM
  #149
Originally Posted by nemsin
Buy a Prius?
always has to be some jackass with this stupid statement.... go back to the Evo IX forums if you don't have a REAL response.
Old Apr 12, 2010 | 09:19 AM
  #150
stlgrym3's Avatar
either that or the dealer sold him/her the car made body swap and in reality sold him/her a regular Lancer.
