Sponsored by:
Sponsored by: CARiD
Seibon trunk leak?
Old Apr 5, 2010 | 11:41 AM
Red08EVO's Avatar
Seibon trunk leak?
I put on a brand new seibon cf trunk, and whenever it rains and I pop my trunk water seems to come pouring out from behind the carpet lining. Anyone else have this problem? Do I have to use silicone on back of taillights and 3rd brake light? Because other than that I don't know where it can be coming from.
Thanks,
joe
Old Apr 5, 2010 | 11:42 AM
ikt's Avatar
ikt
is all the weather stripping intact on the inside of the trunk lid closure?
Old Apr 5, 2010 | 11:46 AM
wiretap's Avatar
On a dry day, get the hose out and spray it down to see where it is leaking through from.
Old Apr 5, 2010 | 11:47 AM
Red08EVO's Avatar
inside of trunk lid? Im not following. There's a rubber ring on the third brake light, and a foam pad type material on back of the taillights. Then the weather stripping on the actual car is perfect.
Old Apr 5, 2010 | 11:50 AM
Spy007's Avatar
If you dust the seal of the trunk with some powder (like chalk powder from a snap line) and then close the trunk, reopen and make sure there arent any spots that dont show chalk on the opposite of the seal. If there are gaps in the chalk, then that might be a spot that doesnt compress the seal well enough.
As for the lights... a little silicon bead around them to seal it doesnt hurt as long as you dont ooze it out of the gaps and onto the outside of the body. Seibon hasnt been known to fit perfectly in all cases so you might have to do some modification. Once you have sealed it all up, definately do the hose test as suggested before and do it to small areas to see if they leak.
Old Apr 5, 2010 | 12:24 PM
turbo911cm's Avatar
good test that I have done before. Get a lot of towels as well to dry off the trunk as you go along.
also, probably will end up washing the whole car when you have found the source of the leak too, so bring your favorite car wash supplies.
Gary@MellonRacing
Mar 26, 2023 12:20 PM
iLLevo_
Oct 4, 2016 12:49 PM
JScocchio
Nov 18, 2010 08:59 PM
03evo4g63
Aug 5, 2006 09:22 AM
mitsuozboi
Mar 3, 2006 07:30 PM
