Sponsored by:
Sponsored by: CARiD
Reverse Lights Work for Only 10 Seconds!
Old Apr 5, 2010 | 06:36 PM
mybmw530i's Avatar
Exclamation Reverse Lights Work for Only 10 Seconds!
I have a 2008 MR with SST transmission. When going into reverse, the reverse lights go on for only 10 seconds, then go off even if the car is still in reverse. The dealer is stumped. I know the SST has it's own ECU that talks to the engine ECU. Any ideas or fixes?
Old Apr 5, 2010 | 06:41 PM
jackygor's Avatar
any things done to your car?
Old Apr 5, 2010 | 06:46 PM
mybmw530i's Avatar
no...car is stock...
Old Apr 5, 2010 | 07:03 PM
Brokenevo's Avatar
lol thats insane lol
Old Apr 6, 2010 | 05:59 AM
evoyao's Avatar
So is it an electronic issue regard to the "Reverse light"? or the car wont go reverse physically?
Old Apr 6, 2010 | 06:07 AM
tephra's Avatar
does the dash show the car in reverse? maybe the reverse signal from the TCSST ECU is getting lost?
Old Apr 6, 2010 | 08:22 AM
Webman's Avatar
Hmmmm.... I've never noticed if mine turned off before. How did you notice it?
Old Apr 6, 2010 | 04:22 PM
mybmw530i's Avatar
Unhappy
Hi guys,,,the car will physically move in reverse, but after 10 secs, the reverse lights will go off, the "R" will flash, indicating a gear block, but the car is still moving. Just hope I don't have to reverse for any length of time in the dark!
Old Apr 6, 2010 | 04:30 PM
mybmw530i's Avatar
The car has only 1200 miles.
Old Apr 6, 2010 | 04:32 PM
monkey_187's Avatar
So the stealership let you drive away with it like that? That is something that they should keep the car till its fixed.
Old Apr 6, 2010 | 04:38 PM
mybmw530i's Avatar
I thought some of you who have SST transmissions might have the same problem. I'll have to elevate the problem up the food chain to Mits.
Old Apr 7, 2010 | 06:09 AM
evoyao's Avatar
The reverse light in the screen will flash if the tranny does not gear into the reverse yet. But it only happens at the first few seconds when you gear into reverse. However, in you case, it is not a normal situation. Hope your car still have warranty because it sounds like reverse gear failed. Good luck!
Old Apr 7, 2010 | 05:08 PM
mybmw530i's Avatar
Thanks for luck! The car is still in warranty. The car still works in reverse. It's the reverse lights that stop working.
Old Apr 26, 2010 | 10:23 AM
ohitisethan's Avatar
yea dude good luck i got the mr and it dosen't do that.
razorlab
Sep 14, 2019 11:08 AM
Peage
Mitsubishi TC-SST Discussion
Jun 20, 2016 11:33 AM
Juke
Feb 16, 2016 08:11 AM
robyn402
Nov 14, 2012 08:33 PM
razorlab
Sep 28, 2011 09:16 PM
